Running Spin on a Mac computer with Virtual PC , questions. — Parallax Forums
JoeJoe Posts: 184
edited 2010-07-24 20:30 in Propeller 1
hi,
I have two similar questions:
1-- I have an Spin code running with my PC and I want
to run it on a Mac computer . Do you know it this is possible
just installing the Virtual PC on the Mac ?
2-- I have an Spin application running with Visual BASIC
on my PC and I want to run the application on the Mac.
( Is this possible ? )
Thanks, Joe
PS: I don't know if Virtual PC is best tool for these jobs.
    edited 2010-07-23 15:38
    There is no Visual Basic for the Mac, but you can indeed run it using Virtual PC on a Mac. If you have a PowerPC Mac, you'll have to use Virtual PC. If you have an Intel Mac, you'd use either Parallels Desktop or VMWare which are similar virtualization environments that let you run Windows on a Mac.
    I had a PowerBook at one time and ran Virtual PC on it with Windows SE so I could use the Propeller Tool. It was slow, but did work. I had to inhibit automatic updates because there were too many download errors to the Propeller when Windows Update ran in the background. Using Parallels Desktop or VMWare on an Intel Mac is much faster and I've not had any problems. Still, I normally use the Mac version of BST now for programming and downloading. This is a Propeller Tool compatible development environment that comes in Windows, Mac, and Linux versions and is downloadable from Parallax's download webpage.
  • Brian RileyBrian Riley Posts: 626
    edited 2010-07-24 03:53
    Mike Green said...
    A couple things here. VPC is all but a dead issue on the Mac and won't run on at least the last two or three iterations of Mac OSX. I gave up on it back at Panther!
    There is no VB on Mac, but there's Real Basic a cross platform suite which is fairly easy to translate to from VB. www.realsoftware.com/realstudio/ .
    cheers ... BBR
    cheers ... brian riley, n1bq, underhill center, vermont
    The Shoppe at Wulfden
    www.wulfden.org/TheShoppe/
    www.wulfden.org/TheShoppe/prop/ - Propeller Products
    www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
  • heaterheater Posts: 3,370
    Let's make life really simple:
    1) Do not us the Propeller Tool from Parallax Inc. (even if you are on a Windows machine).
    2) Use BradC's BST instead. Works like a dream on Linux for me and on the Mac as well.
