"Freeforming" Transistor H-Bridges
I had never heard the term "freeforming" before, which means soldering components directly, no PC board!
http://www.beam-online.com/Robots/Tutorials/Freeform/H-bridge/hbridge.html
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Post Edited (Peter KG6LSE) : 7/22/2010 6:17:37 AM GMT
It's a great way to create a small project with something
like an ATtiny uC. I epoxy a Tiny88 upside down on the
circuit board of those 3.00 ebay 2-line LCDs and just wire
direct to the pins = a less than 5.00 LCD you can control
any way you want. Plus you can use the extra left over
processing power and I/O pins of the 88 to assist the projects
main uC.
justasm.blogspot.com/
www.beam-wiki.org/wiki/Freeform_Bicore_Tutorial
- Stephen
BEAM also stacks ICs to double the power output.
Why limit yourself to following imaginary rules when nobody really is trying to control your creativity. Spend a bit of time making ICs do things that they were never designed for.
In many cases, a hot glue assemby is quite handy as well. Wires don't come loose, lots of insulation; but you can easily do rework.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
You could stick the 6 transistors down into a block of stiff modeling clay.
Do your soldering, and then squirt some epoxy or hot glue to
fix the thing together.
This is ok as long as you never send a high signal to both 3 and 5
at once.....the thing would start to smoke if you did!?
If I did something really involved I would build
it in stages and after testing each stage I would
finalize that stage by covering it with hot glue
We should have a contest to see who could make
a working uC project of some complexity using this
style of wiring....prize to go to the one with the most
outrageously haywire look.
Hmm, I'm thinking of the flyback protection, not protection from intentionally short circuiting your battery (or PS) which is what would happen if you applied +Vcc to one the top half of the bridge, and ground to the bottom half.
From other hbridge circuits I've seen there is normally a diode in parallel with the motor and each transistor of the hbridge. So, there should be 4 diodes for flyback protection from the motor. The reason I ask is that I recall in my Advanced Avionics class in the Navy they told us that a transistor can be thought of as two diodes either anode to anode or cathode to cathode (depending on npn or pnp) with the base wire connection between them. Emitter and collection come from the the other side - so base is connection to both diodes and emitter / collector is connected to only one diode. I just had a discussion with a co-worker regarding this. He doesn't believe me. It's been 20 years since I took BEE so please forgive my ignorance but I have to settle this bet
The zeners would have to be rated higher than the operating voltage of motor so that the only conduct spikes. Maxium has similar ready-made devices for protection of circuits that connect to long wires where transients may creep in an kill a valuable board.
Unlike relays, where a simple diode with serve as flyback protection, you are reversing polarity to reverse motor direction. So a more complex approach needs to be used.
In reality, these devices are for such small motors that I suspect that flyback protection is a bit of overkill.
I really wish I could do more of this kind of work, but at 63 years of age, I tend to shake too much for a lot of fine handy work.
Post Edited (Loopy Byteloose) : 7/24/2010 3:34:58 PM GMT
See, for example, circuits in JunkBots, Bugbots, and Bots on Wheels: Building Simple Robots With BEAM Technology by David Hrynkiw and Mark Tilden.
create bitmap data tool: 1uffakind.com/robots/povBitMapBuilder.php
resistor ladder tool: 1uffakind.com/robots/resistorLadder.php
convert images to ascii art: 1uffakind.com/apptoys/convtoascii/
At Amazon: http://www.amazon.com/JunkBots-Bugbots-Bots-Wheels-Technology/dp/0072226013
I do have the Junkbots book. My only disappointment is that it is getting harder and harder to find good junk. The items mentioned in the book are not so easy to locate anymore.
But I do have a couple of tiny, tiny stepper motors salvaged from 3 1/2" disk drives that can be easily driven directly from a BasicStamp that I ponder about. If I used an SXchip in SMD format (I do have some), I might get the size down to power a little solar robot with a lot of digital control, maybe a line follower.
I've recently seen a·freeformed microcontroller and support circuitry too:
http://www.geocities.jp/arduino_diecimila/obaka/project-2/index_en.html
This looks like a lot of fun. And it could be quite handy as well.
Post Edited (Loopy Byteloose) : 7/26/2010 3:34:16 PM GMT
