A few questions about TMS417400A DRAM
I have a few TMS417400A IC's I scrapped from some old PC memory.· The datasheet says
I only want to access 512K Bytes of the chip, can I limit the amount of address/data pins I connect to the prop or do I have to connect all the pins of this DRAM Chip?
Since I want to use only 1/4 of the memory, wouldn't I only need 1/4 of the address lines?
thanks in advance.
http://WhatsAvailable.org Software and Gadgets for Windows 7.
The TMS41x400A is a set of 16 777 216-bit dynamic random-access memory (DRAMs) devices organized as 4194304 words of 4 bits each. The TMS41x400A employs state-of-the-art technology for high performance, reliability, and low power.
These devices feature maximum RAS access times of 50-, 60-, and 70 ns. All address and data-in lines are latched on-chip to simplify system design. Data out is unlatched to allow greater system flexibility.
Mine is the one with the DJ suffix and 60-ns.··Wouldn't that mean·16,777,216 bits = 2,097,152 bytes making this a 2Mb chip? or did I do that wrong?The TMS416400A and TMS417400A are offered in a 24/26-lead plastic surface-mount SOJ package (DJ suffix). This package is designed for operation from 0°C to 70°C.
thanks in advance.
You do know that you will need to provide some means of refreshing them? It can add quite a lot of complexity, unless you use software refresh.
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 7/21/2010 5:58:39 AM GMT
Leon Heller
Leon Heller
I was just thinking along the lines of, the DracBlade uses a bunch of latches and a lot of that is inbuilt to the DRAMs.
Have you seen, http://www.myplace.nu/avr/dram/index.htm·which is simular to the sort of thing (just with one of those "other" chip thingies).
Why did I think a new, more challenging, job was a good idea ??
Post Edited (Toby Seckshund) : 7/21/2010 7:25:30 AM GMT
Yes, I am just bored and playing around with the idea. It is something I found in my parts bin I just dug out of storrage.
EDIT: I am trying to not use all the address lines....
The problem with multiplexed addresses is that every address line you leave out, it will divide the available space by FOUR, not just two.
So in the end you just spare ONE pin to get from 4Mx4 (2MB) to 1Mx4 (512KB).
However if the chips are not mounted on a module, then you have control of the output enable pin (not fixed to low like on SIMMs), and you MIGHT be able to combine data and addresses, like the example in the link that Toby suggested.
Alessandro
Post Edited (AntoineDoinel) : 7/21/2010 9:44:48 AM GMT
