Using the 74HC165 with StampWorks Sample Code
JD
Hello Everyone,
I was working on a Parallel-in/Serial-out 8-Bit Shift Register; and the code in the StampWorks manual was not working. I always got the 7th and 8th bit to change at the same time.·I read the datasheet and once the load pin was brought HIGH, the register could be sampled and·then load pin brought LOW is saved all 8 bits correctly. It confused me a good bit the other night, but wanted to share in hope it saves some time for someone else.
JD
JD
bse
1K
