vmusic
dear all,
·i have problem and really i don't know wat is the wrong? i have· Vmusic.mp3. i use it with b2c mircontroller.. with i download the music in the flash momery....
i use this coding to run one music from baisc to speak throuhg vmusic, but it doesn't play...
SEROUT 0,84,[noparse][[/noparse]"VPF test.mp3",CR]·········· 'Play a file named "test.mp3"
but this command it does play but it let all music plays
SEROUT 0,84, [noparse][[/noparse]"V3A",CR]·················· 'Command to play all mp3 files.· It will play whatever file it first finds
·but it let all music plays
best reagrads
best reagrads
1) Try using the VMusic2 using some kind of PC interface so you can type in the commands and see the response of the VMusic2.
2) Attach your whole program as a text file using the Attachment Manager that you get when you use the Post Reply button.
I've used the VMusic2 before with both the Stamps and the Propeller. I did #1 first to understand how the various commands worked.
Ive been wanting to reflash my vmusic from the pc, but dont know how to wire it to a usb cable, and I cant seem to find a programming cable for it anywhere.....do you have any info on this?
thanks, its working now, found an old 32 meg flash drive, and it was up and running no problem
