Best direction to start for a Propeller-based TV GUI?
Oldbitcollector (Jeff)
I'm starting on a Propeller based GUI. (TV based)
Has anyone done any groundwork here? IIRC, Doug's driver supported a cursor at one point or another.
I don't really care about the resolution or if it can only display a few "icons" at a time, just simplicity.
Edit: A pictures is worth a thousand words, so here's what I'm driving toward.. With less Chinese of course!
This should be doable on a prop, no?
OBC
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
Post Edited (Oldbitcollector) : 7/18/2010 7:07:25 PM GMT
OBC
Have you looked into the Hydra? I remember seeing a GUI for the Prop., and I'm pretty sure it was in Andre LaMothe's Hydra Manuel.
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Did you ever get into character/icon based display with your VGA GUI or just text and windows?
OBC
Text based GUI for VGA_HiRes_Text Driver:
obex.parallax.com/objects/413/
It isn't the "desktop" and "windows" based model, but it does have various form gadgets like text boxes, buttons, and lists.
I have seen another guy working on a similar thing recently...
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
Bill
The only bad thing is that he beat me to it.
Check out my new website!!
Use the Propeller icon!!
OBC such a GUI is possible with fewer colors of course.
Propeller Pages: Propeller JVM
Post Edited (jazzed) : 7/19/2010 4:53:36 PM GMT
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
Safety Tip: Life is as good as YOU think it is!
No one seems to be bothered about hooking up an SD card at some point...
OBC
OBC, SD is not fast enough even for NTSC frame buffer, and would wear out.
Once I get the drivers running, FlexMem using the two-cog driver will be (barely) fast enough to do a NTSC 127 color frame buffer, but updates will be very slow, and at least three cogs will be required. Updating the screen will be a pain in the posterior, as a minimum of four bytes has to be read/written to change one pixel. It will be SLOW.
With frame buffers, there is no such thing as free lunch.
horiz_pixels * vert_lines * 60 = pixels per second
pixels_per_second * bits_per_pixel / 8 = bytes per second
bytes_per_second is the ABSOLUTE MINIMUM memory speed you need to just show that frame buffer
You really need (2 * bytes_per_second) if you need to update the screen.
And you need to allow time to set up addresses etc.
For example:
256 * 192 * 60 = 2,949,120 pixels per second
2,949,120 * 2 / 8 = 737,280 bytes per second - FlexMem can do this
But remember,
256*192*2/8 = 12,288 bytes - it fits in the hub, no need for external memory (256x192 4 colors per pixel)
320x200*2/8 = 16,000 bytes - it fits in the hub (320x200 4 colors per pixel)
320x240*2/8 = 19,200 bytes - fits, but not much room left over (320x240 4 colors per pixel)
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
A video solution to adopt is a driver that can load buffers using any hardware with reasonable speed.
Add Morpheus or other hardware that is fast enough to a VMCOG like driver that can deliver 10MB/S.
I agree, an abstracted frame buffer refresh / screen update HAL is a good idea. VMCOG can't do it, but the same interface could be used.
Oh no you don't! Not until Propcade and Flexmem are online for sale... [noparse]:)[/noparse]
You don't want me to start chanting: FLEXMEM, FLEXMEM, FLEXMEM again now do you?
It does sound like you've got the answer. Not only that, but it doesn't look too expensive or complicated.
Bring forth the FLEXMEM! [noparse]:)[/noparse]
OBC
