Need Help reading form EEPROM
Let me start by saying that I am VERY new to Propeller and Spin. I am having a problem and I have searched the forums to no avail.
I have a spin application running on my Propeller that is launching 6 cogs to each do the same thing, only with different pins.
Here is a bit of my code that I will explain.
EXPLANATION
So, if I run this app, it works great. No problem at all as long as I only request data from 1 of the cogs. As soon as I request data from a second cog (Does not even have to be simultaneously) it does not read the EEPROM correctly. I reboot the Propeller and it works fine again, until I try to have another cog read from the EEPROM.
Can someone point me in the right direction. Keep in mind I have no experience with Spin. I have this project running flawlessly on 6 Basic Stamp 2e chips, but I want to consolidate to a single Propeller running 6 cogs.
BTW, if I omit reading from the EEPROM to get the next character, and instead use a predetermined character, the program runs without a hitch. However, I need to be able to pull this data from the EEPROM and send it out a pin via serial communicaitons.
Another possibility would be to read it once on bootup and store the data in a variable, but it is 129 bytes of data per channel and I don't know how to go about that.
Thanks in advance for any help you can give me.
Ryan
OBJ BS2 : "BS2_Functions" ser : "TRXEngineModified" PUB Main cognew(StartScan(1),@cogSpace1) cognew(StartScan(2),@cogSpace2) cognew(StartScan(3),@cogSpace3) cognew(StartScan(4),@cogSpace4) cognew(StartScan(5),@cogSpace5) cognew(StartScan(6),@cogSpace6) PUB StartScan(chan) | rbyte, txPin, rxPin, i, sAdd, eAdd txPin := (rxPin := (chan * 2) - 2) + 1 'set the transmit and receive pins based on the channel we are monitoring repeat rbyte := ser.receiveCharacter(19200, rxPin) 'This section is working fine...FROM HERE... pause(200) if rbyte == 77 ser.transmitString(string("M?:009A",13,10,13,10), 19200, txPin) elseif rbyte == 65 ser.transmitString(string("WR:",13,10),19200, txPin) elseif rbyte == 76 'This section is working fine...TO HERE eAdd := (sAdd := (chan - 1) * 150) + 130 'Set the beginning and ending address to read from the EEPROM repeat i from sAdd to eAdd ser.transmitCharacter(BS2.Read_HighMem(i, 1), 19200, txPin) 'This is the part I am having a problem with. See EXPLANATION BELOW sAdd~ eAdd~ i~ rbyte~
EXPLANATION
Ryan
I'm not a spin expert but you appear to be trying to access the one eeprom from six cogs(??).
If so this·can be a problem··as all cogs would be trying to access the eeprom simultaneoulsy and also·input/output pins are OR'ed together. If one cog leaves a pin in a high state it cannot be set low by another( ie 1 or 0 =1).
Regards
Gerry
Your idea of reading the table from EEPROM into a variable (or set of variables) is a good idea. You could easily have a 6 x 129 byte array (774 bytes total) since the Propeller has more than enough memory for your project. You'd access the array using the channel number and index like "table[noparse][[/noparse] chan*129 + i ]" and you'd just declare the array as "VAR byte table[noparse][[/noparse] 6 * 129 ]".
Note that it's impossible to tell what you're trying to accomplish from your program fragment. If this data table is fixed, you could simply define it in a DAT section like:
and so on for a total of 774 values.
Nyamekye,
Gerry, I didn't know that if a pin is set high by one cog, it cannot be set low by another. That's good information for me moving forward. Thank you for that.
Mike, I like your idea of using the byte array. I am used to Visual Basic and was getting hung up on the table[noparse][[/noparse]1..6] but then realized that I can't hold an entire string in each element of the array. Since I can't have a two dimensional array (matrix) I thought that method wouldn't work. Your suggestion of table[noparse][[/noparse] chan*129 + i ] is a great idea. I will try that next and let you know how it works out. The data table is not fixed, but very rarely changes. If I could read it from the EEPROM on bootup and store it in the variables, that would be great.
Kye, I have just downloaded your code and it looks great. BTW, I really like the simplicity of the TRXEngine. Thank you for your contributions.
I really appreciate all the help.
Ryan
If a pin is left low when a cog is finished with it, can another cog then use it switching it low and high and then leaving it low again ?
I have a serial LCD Display that I can only send data to form one cog. If I try to output to it from another cog, it doesn't display anything. If I got back and trigger an output to it form the original cog, it displays fine. Could that be my problem there ?
Ryan
PS. Still working on the EEPROM read into memory. I will post once I resolve that and let you know what worked best.
Now I just need to clean up the function that writes to the EEPROM for updates.
Thank you so much for all of your help.
Ryan
If you look at page 26 of the Propeller Manual it explains how the I/O resources are shared by the cogs, better than I could explain it.
you can get a copy of the manual here
http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerMediaPage/tabid/832/Default.aspx
Gerry
Thanks for your help.
Ryan
Now, for timeout just do this.
The code my be wrong but the idea is to just keep checking until the I/O line goes low as fast as possible until the time is up.
Nyamekye,
Ryan
