What is the PS2 connectors name in the Eagle lib?
I see a few connectorss that look like they could be it under con-yamaichi.lbr, the MD06S or the MD06SS?· They both look like a 6pin din but I wanted to ask first before I use it, I need the 6pin mini din...
Also looking for the RCA Jack used for video, cant find it.
http://WhatsAvailable.org Software and Gadgets for Windows 7.
mini_din
and it is called MINI_DIN_6
pin 3=Gnd, pin 5 = 5V, Clock = pin 6 and Data = pin 1
I found an RCA connector in the
con-conrad
menu, with the device number 736880
Let me know if you need these libraries.
www.smarthome.viviti.com/propeller
I am looking for libs that are commonly used with the propeller, and or stamp. I thought I saw an eagle lib on parallax's main site...
Put in in the lbr folder.
But it is really complicated adding a library. I've never worked out exactly what step works, but if you open your project, in the Library tab is Use, Open, Update, and Update All. I usually click all of these in order, then shut down eagle, then start it up, then repeat, then shut it down and start it up and finally it appears in the list when you go to add a new part. I've never worked out exactly which of these steps adds the part though.
Let me know if you have any problems.
As for search, you can sometimes find more things with wildcards eg *bc547*
But usually it is a matter of tediously going through things.
What sort of parts are you adding - I might have some more libraries and/or hard to find parts.
Thanks and I do have the parallax_propeller.lbr
Since most use eagle instead of PCB Artist, I will try to add all the parts that are sold by parallax to a single lib, it would make it easier for me that way, I dont know about anyone else...
Thanks again
Leon Heller
Amateur radio callsign: G1HSM
