Recommend low cost reflow oven?
I am just doing low volume hobbyist type of stuff, currently using a hot air station and a quarts pre-heat station. I am thinking of stepping up to an oven. But my pockets are not too deep. Can anyone recommend something less than $1,000 that would perform OK for my needs? I see some cheap units on eBay for $400, but not sure of quality.
Thanks for any input.
Larry G.
Larry G.
Post Edited (T Chap) : 7/16/2010 3:29:24 PM GMT
Should I get one that has the convection feature?
Post Edited (LarryG) : 7/16/2010 4:00:42 PM GMT
I put the boards right on the rack with no trays, slide the tray in after placing the boards carefully on the rack. Too fast and you might displace a part.
Press "convection bake", press "temp", bump it to 300, press "timer" and set to 3 min, press "start". At 3 minutes it will beep to let you know the timer has stopped, then press "temp" and bump it to 450, press "timer" and set to 2 minutes. It beeps when done. Flawless every time. I always use convection, makes for nice heat coverage.
You would think this oven was designed for reflow.
Post Edited (T Chap) : 7/16/2010 4:41:15 PM GMT
Thanks again.
-Larry G.
The July issue of Everyday Practical Electronics [noparse][[/noparse]a British publication found in some bookstores] has an article on soldering surface-mounted devices. In it there is a discussion on using a toaster oven.
cheers, David
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
