Sumo-Bot Help!!
Im having trouble with my sumo-bot. When I run the competition code, all it wants to do is go straight. None of the sensors seem to work, but when I test them individually, every single sensor works perfect. I know my battery level is good and I have everything wired correctly but for some reason the competition code doesnt do what it should. Anyone else have this problem or solved it? Any ideas to what may be causing it to do that?
- Stephen
