A simple LED question
I want to have a set of LEDs that I can turn on and off. They should ALL go on and off at the same time. That is, I'm not trying to control each one individually. I went to http://led.linear1.org/led.wiz to design the array of LEDs, mainly because I wanted to make sure I'd use the correct resistors for the array. It lets you specify the properties of the LEDs and battery that you're using and it generates a circuit diagram. For my multi-LED circuit it shows that each LED has its own resistor. It's basically two parallel wires (for the + and - lines from the battery) with a set of resistor/LED pairs connected between them, i.e. a parallel circuit.
I understand the need for the resistors, in order to bring the voltage down to what the LED expects. But, I'm wondering, shouldn't it be possible to have a SINGLE resistor (near the battery, on the positive terminal side) instead of a separate resistor for each and every LED?
For example, say you have a 12V power source and you're using red LEDs with a forward voltage of 1.7V. If you put six in series, that's 6 x 1.7 = 10.2V. With a 12V power source, that's 1.8V you need to drop in the resistor. If you want a 10mA current, by Ohm's Law, that's R = E / I = 1.8 / 0.01 = 180 Ohms.
Also, it (single resistor) assumes (this is a bad thing to do) that all LEDs will behave identically. If one or two have a low internal resistance, the signle resistor concepts breaks down similar to above, just more gradually (at first).
Your best bet is to always have a "series" circuit where all current for a given loop will go through the resistor and LED.
I gues you could possibly do some LEDs in series, but this gets back to assuming they all behave close enough to the same to not cause damage to one another, and you would also get the old "one goes out, they all go out" thing.
John R.
Click here to see my Nomad Build Log
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 7/15/2010 9:36:59 PM GMT
Hawaii must be very nice this time of year.
I drive all my leds from 74hc595 shift registers, (out of spec) you should but don't need resistors - as the 595 puts out about close to a max of 15ma for red LED's for example - near their max brightness. On one of my breadboard circuits I am driving 80 LED's in parallel at around 1.4A at 3.3V or 5W for the whole circuit (Propeller, eeprom and 10 595's on top of the 80 leds).
The max power from the 595's (LS or HC) is enough to multiplex 8x8 displays with 2 595's with very good brightness.
I never drive led's directly from a propeller and then don't have to worry about overloading it - I find that the 595's (available from parallax are indispensible) and allow you to use only 3 pins to drive an unlimited amout of LED's.
Here is clean circuit where·one·595 drives another·595 powering the·rows with a·138 driven by the low high bits of the first 595 - drives the common cathode column of 4 led digits
thank you
/michael
Post Edited (Michael O'Brien) : 7/16/2010 3:08:18 AM GMT
