Need help with 16/14 segment led display code
obex.parallax.com/objects/545/
The above is the code I'm using only added 4 more digits with a 2nd PPDB which had been damaged & now otherwise worthless.
The problem is 8 of 10 characters work as expected, however the 2 on the far right does not. They both display jarbled junk. On the program all I had changed is the paramaters for the pin set up from 6 to 10 on the two lines at the top. All other characters display correctly, so I know it's can't be a wiring issue. Can anyone help me on this?
Joe
I'm going insaine. It's SOOOOOO much fun. lol
Joe
This is the problem. It seams to be combining characters into those 2 sections. I tried adding 12 characters, but get 4 char like that instead of 2. Maybe Steve Stuart the guy who wrote it could chime in? I tried moving the I/O pins around but no help. I'm at a loss here.
Joe
Joe
Joe
Post Edited (jknightandkarr) : 7/16/2010 4:28:15 PM GMT
I haven't looked at the 16-segment object, but I wrote the 7-segment object in the OBEX. Is it possible that the digit select pins aren't being controlled correctly? It looks like the segments on those last two characters are a union of all the segments from all the other characters. That would happen if those select pins were always low.
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our first album on the iTunes Store
Our second album...
Joe
Joe
Joe
I just tried the object you link to and it works fine.· I modified it for 10 digits without too much trouble.· It displays fine on the two PPDBs I have.
Duane
Joe
I just redownloaded it, my version is 1.3, I just got 1.4. I'll try it now.
Post Edited (jknightandkarr) : 7/18/2010 3:22:09 AM GMT
Joe
Post Edited (jknightandkarr) : 7/18/2010 4:40:31 AM GMT
in a repeat loop setting each digit & the character in the outa sections. I've added a DAT area with all the letters & numbers already filled out, just using the ol variable bit to reduce program size. I've tried going through each section of the program Mr Stuart wrote & I can't seam to find the answer to my problem, so if he could pop up or if someone could tell me his board id it would be much appreciated. Thanks.
Joe
http://forums.parallax.com/forums/default.aspx?f=25&m=411807
Jim
Joe
I have made a change to the object and posted an update to the obex.
Steve
Joe
Joe
