doubt
I am working on with PINK. I want to send data to pink variable and then display it on the web page. so example program DS 1620 instead of debug I used serout.
DO
HIGH 10
SHIFTOUT 12,11,LSBFIRST,[noparse][[/noparse]170]
SHIFTIN 12,11,LSBPRE ,[noparse][[/noparse]x]
LOW 10
degC=x/2
SEROUT 15,396,[noparse][[/noparse]"!NBOW06:degC",DEC degC,CLS]
PAUSE 1
LOOP
and to get it on the web page, I used the html code
<html>
the value in variable 06 is : <Nb_var06>
</html>
I am not able to display onto the webpage.
DO
HIGH 10
LOW 10
degC=x/2
PAUSE 1
LOOP
<html>
</html>
Can you see the PINK on your network?
Have you used the sample programs?
Tom Sisk
http://www.siskconsult.com
' {$STAMP BS2p}
' {$PBASIC 2.5}
SEROUT 14,396,[noparse][[/noparse]"!NBOW06:25",CLS]
END
do I have to go modify the variables in the System Variables
Hopefully someone else will join in the conversation before then.
Tom Sisk
Try to replace with this code, the only difference is that·your O in·!NBOW06 is replaced with a zero, !NB0W06:
Hope this helps!
Additional note:
When writing to memory location 06 I think you write to Pink's Flash-memory, (00-19). I guess this memory have limited life, like in the BS2, ·so I prefer using memory location 20-99 for fast-changing data.
Post Edited (Moskog) : 7/18/2010 4:47:50 PM GMT
