Balance-bot + PID
I am trying to build a balance-bot using J. Wood’s IMU/Kalman filter program (which works great) and a PID loop. I have experimented with just using a P loop and a PD loop without anything close to success. My problem is that no matter how I set Kp and/or Kd, my bot goes into oscillations of increasing amplitude. I have no prior experience with PID loops but I have read available material and constructed mine based on what I have read.
The balance bot hardware consists of a 5-DOF IMU mounted near the battery at the top of the bot. The motors and wheels are from the Parallax 7.2 V motor, bracket and wheel kit along with 2 HB-25 motor controllers. The processor is the propeller mounted on the Propeller USB proto board.
My PID software is listed below. I would greatly appreciate any help that can be offered. Thanks.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
CS = 20
DIO = 19
CLK = 18
CLS = 16
CR = 13
Kp = 8.0
Kd =1.5
ki =0.0
low_offset = 640
high_offset = 700
setpoint = 86.0
OBJ
IMU : "IMU"
debug : "FullDuplexSerialPlus"
fstring : "floatstring"
fMath : "Float32Full"
Var
long current_angle
long speed
long P_correction
long t
long total_correction
long angleDec
long angleRound
long accumulated_error
long I_correction
long prev_error
long error
long D_correction
PUB main
debug.start(31, 30, 0, 57600)
waitcnt(clkfreq*2 + cnt)
debug.tx(CLS)
IMU.start (CS, DIO, CLK)
fmath.start
ctra[noparse][[/noparse]30..26] := %00100 ' Configure Counter A to NCO
ctra[noparse][[/noparse]5..0] := 5 ' Output pin 5
frqa := 1
dira~~
t := cnt
repeat
current_angle := imu.get_angle_Roll 'get current angle fom IMU
error := (fmath.fsub(setpoint, current_angle )) 'determine error
P_correction := (fmath.fmul(Kp,error)) 'determine P correction
D_correction := (fmath.fmul(Kd,(fmath.fsub(error, prev_error)))) 'determine D correction
prev_error := error
accumulated_error := (fmath.fadd(error, accumulated_error)) 'I AM CURRENTLY NOT USING THE I
I_correction := (fmath.fmul(Ki,accumulated_error)) <# 100.0 'determine I correction with max
total_correction := (fmath.fadd(fmath.fadd(P_correction, D_correction), I_correction))
debug.str(fstring.floattostring(current_angle ))
debug.str(string(" "))
debug.str(fstring.floattostring(error ))
debug.str(fstring.floattostring(P_correction ))
debug.str(fstring.floattostring(D_correction ))
debug.str(fstring.floattostring(total_correction ))
debug.tx(CR)
compute_speed
run_motors
pub compute_speed
angleDec := fmath.fround(total_correction)
if (angleDec < 0) 'I have tried different windows besides 0 such as +/- 1 through +/- 4
speed := clkfreq/(angleDec+low_offset) <# 160000 'max speed back = 1ms
elseif (angleDec > 0) 'offsets are values where wheels start to spin
speed := clkfreq/(angleDec+high_offset) #> 80000 'max speed fwd = 2ms
else
speed := clkfreq/665
pub run_motors
phsa := - speed ' Send the countdown pulse (speed)
t += clkfreq/100 ' calculate delay between pulses
waitcnt(t) ' THE DELAY BETWEN PULSES IS CURRENTLY COMMENTED OUT since debug statements
' create ~ 10ms wait between pulses
CON
CS = 20
DIO = 19
CLK = 18
CLS = 16
CR = 13
Kp = 8.0
Kd =1.5
ki =0.0
low_offset = 640
high_offset = 700
setpoint = 86.0
OBJ
IMU : "IMU"
Var
long current_angle
long speed
long P_correction
long t
long angleDec
long angleRound
long I_correction
long prev_error
long error
long D_correction
PUB main
debug.tx(CLS)
fmath.start
frqa := 1
dira~~
t := cnt
repeat
prev_error := error
debug.tx(CR)
compute_speed
run_motors
pub compute_speed
else
pub run_motors
People generally are not too interested when someone just posts a large block of code or a whole complex program. It's better if you ask specific questions rather than "what do you think of this?" or "this doesn't work, what do I do?". In your case, you did describe what's going on, but the forum formatting messed things up. Since you have debugging statements in your program, you might give some examples of the values shown as your program "misbehaves".
Post Edited (Mike Green) : 7/14/2010 8:54:42 PM GMT
1. Normally in a pid the Kd term uses time, if you are very sure the delays are constant you can bundle the time into the constant but it is often better to div the error term by the time from the last tick before multipying by Kd.
2. Are you sure the kalman filter is working correctly. I have had cases where the axises are wrong (e.g. accelerometer X axis and gyro Y axis) and the filter looks like its working but was tracking slowly because it was really only working off the accelerometer - the effect was the feedback response was slow
3. Generally when tuning a PID, you set Ki and Kd to 0, then start with Kp small and increase until you get oscillation and then decrease Kp until oscillation stops and then tune the other constants
4. The setpoint is 86.0 I assume this happens to be the upright angle for your bot
Lawson
Lunch cures all problems! have you had lunch?
John Abshier
I tried both negative a positive Kp/Kd's without success. I think that the Kalman filter is working since the change in angle seems to be very fast and sensitive when I read it on the terminal. I will try dividing the error term by time and see if it makes a difference. The setpoint of 86.0 is the angle that the bot is perfectly balanced upright.
I put offsets (forward and back) into the compute_speed routine because there is a "dead zone" where the speed values do not provide enough motor torque for the wheels to turn given the weight
of the bot (about 3 pounds). The if-then statement directs the correction to be applied to the proper offset. The min/max limits keep the speed value within the limits of the motor controller. I have debugged speed and the values seem in line with what I would expect, but I will look again.
I'll keep working on it. Any additional suggestions are more than welcome!
You need to print the accelerometer and gyro sensor inputs as well as the imu output and compare the times of when they change compared to the imu output.
I have attached a plot of when I did it. The top line is the imu output, you can see the delay - its ~1/4sec. The other 2 lines are the gyro and acc· raw from the sensors. The gyro being the short spikes, you can see the gyro returning to 0 before the imu really changes, 1/4 sec doesn't seem a lot but it was enough that it meant the imu wasn't keeping the quadcopter stable.
Even just printing the sensor data would help, print it and then rotate round 1 axis and check the expected sensors are changing.
@Tommore: Lovin' your graphing - any chance of releasing that software?
</OT>
Cheers,
Simon
www.norfolkhelicopterclub.com
Announcement: To cut costs in the current economic climate, we have switched-off the light at the end of the tunnel.
I didn't re-run the test, I had the log file saved and loaded it into the config app and it loads it in as if it just did the run. The config settings are set correctly, the chart loaded, etc. Takes some time to load depending on the size of the file since that wasn't the goal of the app but it works and is surprising useful.
Post Edited (Timmoore) : 7/16/2010 2:31:42 AM GMT
hi Timmore,
at your answer from 07-15-2010 i see the screenshot of your Quadcopter-Interface
it's looks cool
its possible to share your source-code ????
i am working on my quadcopter
in the moment i working on a 3D-Simulations of a quadcopter
with wings3d, opengl, OpenSceneGraph, ODE
and i am verry interessting on your source-code....
many thanks...
regards nomad
excuse me for the late answer. thanks for your code
(at quadcopterThread page 21)
regards nomad
