Using the Propeller as a clock generator
I'm working on a project that will use a digital frequency synthesizer (DDS) chip. I plan to derive the master clock for the DDS from the Propeller counter - probably in the 0.5 to 2 MHz region.
I'd like this clock as stable and jitter-free as possible, which leads to two questions:
1) Am I correct in assuming that some division ratios of the Propeller clock are cleaner than others? Like, for instance, clkfreq / 2^n
2) Alternatively, is there any drawback to tapping a signal off of pin XO (P29) of the Prop chip directly? (Through a CMOS buffer. If there's a slight change in xtal frequency due to buffer input capacitance, it won't matter, as long as it's stable.)
Thanks for any insights,
2) I'd be inclined to avoid messing with XO. Use a counter output instead.
Also, be aware that the DDS, like the Prop, uses an NCO and will introduce its own jitter, albeit not nearly as much as the Prop, since sine waves have "softer" edges.
Here are a couple of my own threads on the subject:
http://forums.parallax.com/showthread.php?p=912712
http://forums.parallax.com/showthread.php?p=921101
Calming the jitters is something that I'm very actively pursuing at the moment. I've also bought a DDS chip but have not tried it yet.
Post Edited (Phil Pilgrim (PhiPi)) : 7/14/2010 6:48:24 PM GMT
Some years ago, I and one of my co-workers collaborated on an investigation of noise in a DDS, and we published a paper on the subject. I don't have a copy of it, but if you're interested, I can probably find out where you could obtain one.
- LC -
·In my AD9833 DDS experiments I used a cog counter to generate the reference clocks and when I did not have a power of two in the freq control field, a 25MHZ setting , I had much more jitter than when I used 2^28 for the control value and generated 20MHZ for the clock. The best way to put it other than visual on the scope was to say it was a task to get the scope trigger to lock on without a power of two in the control field.
AD9833 discussed here http://forums.parallax.com/showthread.php?p=891299
Phil
·AD9833 will not do 14MHZ but here is an interesting link with some videos. I found it just looking for DDS info on the net. DDS60 board looks interesting. You have to go to the bottom of page then home to get to main page.
http://midnightdesignsolutions.com/HC908VFO/index.html
Tom
Leon Heller
Amateur radio callsign: G1HSM
