Peak >210 value/sec to CSV file with DataLogger_Lite_Driver
A lite version of the 'DataLogger_UART_Driver' object has been placed at OBEX:
http://obex.parallax.com/objects/641/
More than 210 ASCII format value/sec peak transfer speed can be achieved with 115K baud UART.
Measured peak write speed was between 210 to 238 ASCII format data/sec,· depending on make and kind of thumb drive.
Due to buffered operation of the driver, ~200 ASCII format value/sec was common at 57K baud UART.
Please note that the >210 value/sec write speed might not be available in a given application, where the data collection and· data processing byte code is interpreted with COG0, along with the driver's code. I recommend to interpret data collection procedures with separate COG(s) paralel.
Available CSV procedures in the DataLogger_Lite_Driver:
To append a line to a CSV file
·· Line_New
·· Line_Append_Int
·· Line_Append_Qval
·· Line_Write_CRLF
To random access read any line from a CSV file
·· Line_Seek
·· Line_Read··
To random access read any data from a CSV line
·· Value_Read··
The new driver comes with all the standard File and Directory operations.
Cheers,
Istvan
Intentionally Left Blank
·· Line_New
·· Line_Append_Int
·· Line_Append_Qval
·· Line_Write_CRLF
·· Line_Seek
·· Line_Read··
·· Value_Read··
Cheers,
Istvan
