Link to the video? That would help. It would probably be something you would have to make yourself and, once made, depending in how you connected it then you would write the code.
Based on the comment on the Youtube link, he used a mechanical linkage from the same Ping rotational servo.·He converted left to right motion to vertical motion with some sort of cam device?
Jim
Harry Brown said... I may have seenit elswhere, but this is all I remember.
If you watch, you can see that the "eyebrows" stay up in some areas, even as the Ping[noparse]:)[/noparse])) is pivoting. It also looks like a 2nd servo wire going in there. I think he has a "micro servo" behind the Ping[noparse]:)[/noparse])) board, and the brows are one piece of formed metal attached to the servo horn.
You may be right John. I didn't spend a whole lot of time trying to dissect it. If I where to do it, a micro servo dedicated to just the eyebrows, so they would be independent and have the ability to move at will.
Jim
John R. said...
- Stephen
Jim
John R.
Click here to see my Nomad Build Log
Jim
