The uM-FPU V3.1 Floating Point Coprocessor is not a Parallax product, although they do sell it. You might find an Application Note on the manufacture's page:
Bottom right click on Application Notes (Off Site)
Shows how to use the ADC. I looked at the datasheet and I can't find anything on using the ADC at least I can't find anything searching the PDF for ADC or the pin names.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Could you post a link to the coprocessor you are referencing?
- Stephen
http://micromegacorp.com/
Jim
Application Note 34 - Measuring Water Level with the MPXM2010GS Pressure Sensor
From the link http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/v3/List/0/SortField/4/ProductID/401/Default.aspx
Does this help?
http://www.parallax.com/Portals/0/Downloads/appnt/stamps/bs1Appnotes.pdf
[noparse][[/noparse]reference page 33 of 126]
cheers, David
