2.5 editor files for BS2P
When I installed version 2.5 stamp editor I noticed the number of files contained under the BS2P folder are way less than what is in the same folder under the 2.0 version.·· 15 vs 53 files, why is that?·· I have not used 2.5 yet so I don't know if it works other than opening up ok.
There should be 15 file in each case.· If you have 53 files in version 2.0, you may have been storing files there without knowing it.· You can tell by the dates of the files.· You should have files from April 2005 and July 2006 in that directory.·
Dave
Dave Andreae
Parallax Tech Support·
