SMT hand soldering videos from UPEW — Parallax Forums
RaymanRayman Posts: 16,458
edited 2010-07-13 00:34 in Propeller 1
Just posted a couple videos from my UPEW presentation on YouTube...
Note that my volume production method uses a stencil, solder paste, and a convection oven, an entirely different technique (maybe something to show next year).
This method is for prototyping or low volume work.
Here's the first one (intro):
http://www.youtube.com/watch?v=3E12lH0OJl0
So far, I got this intro and the first two soldering videos posted...
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
  • HarleyHarley Posts: 997
    Rayman,
    Sure looks easy when YOU do it. But with the right equipment I suppose it isn't as bad as it seems. I've seen videos on soldering SMD devices and I looks like it could be fun. In a way.
    Like doing 100+ pin packages. First tack one corner, then a far diagonal lead, the each lead down every side. Some flood then solder-wick it away. Seems wasteful, to me. But the results in the videos were amazing. Looked like it was automated process, yet done by hand.
    I looked over my PTP board. Nice layout and solder job. Being put to work.
    Helpful video, thanks.
    Harley Shanko
