Programming cable
Hello!
I have noticed that when I have loaded my application into
the propeller ram and I run the app. I can get hasardous results.
But when I unplug the programming cable (the ordinary USB) the app.
runs perfect.
What do I wrong?
Sincerely
Christer Svensson
runs perfect.
What do I wrong?
Sincerely
Christer Svensson
In your case, you may have some sort of ground loop issue. What are you using for a supply?
"A government big enough to give you everything you want, is big enough to take away everything you have. "
- Thomas Jefferson
Thanks for replying.
In this case I used a 9v battery!
Christer Svensson
