please please please HELP ASAP
I have to finish this project tonight. I am starting new job tomorrow i modified the tool chest i am taking to work to unlock the doors via RFID. It works great on my propeller professional development board, so i put it on a bread board it worked great.... until i shorted the 3.3 volt power to the 12volt power. oops!!!
Pulled the board and made new one just like the one that i had that worked perfect only difference is the new board has sockets for eprom and propeller. It loads the program just fine but then it dose nothing i have not changed the code. i have double checked all solder connections double checked to make sure all the pins were getting proper connection tried new propeller chip nothing works any suggestions all pins are getting proper power. I will check back in an hour please help me.
Jim
You need a repeat somewhere in your program·so it doesn't end, but "outa[noparse][[/noparse]25] := 1" only needs to be called once.· The LED should stay on until you turn it off or the program ends.
Duane
Edit: fixed typo
