getting motor (DC) down to 2 RPM
Hey, this is my first post. Just got the discovery kit and have been enjoying it tremendously.
I also bought the HB-25 motor controller to drive a DC gear motor.
My application has the motor turning in one direction until a limit switch is hit, then waits for me to push a button, then goes in reverse until another limit switch is hit.
The problem is with the 12VDC gear motor (50in-lbs) I have does not have enough torque for the load.
I took a 24VDC motor out of one of my kids elec vehicle toys (this motor is at least 10X bigger than the 12VDC gear motor)...that works but spins too fast. I can slow it down, but lose the torque.
I do have this which may be choppy, but give enough of a pulse to move, then delay, so with the load may give just a few rpms:
DO
PULSOUT HB25, 750 + 50 'Motor 1 Forward Slowing
PAUSE 100
PULSOUT HB25, 750 ' Stop Motor 1
PAUSE 1000
LOOP
I am·trying to find another higher torque gear motor....
Is there any way to get that 24VDC motor (form kids elec vehicle) down to 2rpm and still have some torque?
Any other Ideas on what I can do with the program PBasic?
Maybe a stepper motor?
I' ll post some pic latter
Thanks!
-Grant
DO
PAUSE 100
PAUSE 1000
LOOP
Thanks!
-Grant
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Martin_H) : 7/11/2010 10:58:43 AM GMT
A servo has a build in gear box, so it can have a lot of torque, and as it
has a build in driver .. you only need one pin to control it.
And you can specify the angle at which it has to be, a draw back is that
the angle you can put it in is limited. Unless you modify it to be
just a motor with gear by removing the electronics and endstops.
Which also might be convinient for you as you can use the servo horn
to control end switches.
What i used when i needed to turn something very slow was the motor
from an old CDrom drive. It is a brushless motor meaning you have to
make a 3 phase signal to drive it. Which took like 6 transistors and 6 diodes
but it can run at very very slow rpms, and you can glue a CD on it to drive things.
Thanks for the help. I did promise some pictures...
Here is the 50 in-lb motor and gear reduction assy
This is the 1st doner vehicle a Razor Chopper
Out of this came a 24V (250W) DC motor THAT has a lot of torque, but not at low speed. This is the motor and my test setup
Now here are the·2nd doner vehicles a couple of electric kids vehicles. Saw these in a dumpster a few days ago, grabbed them this morning
Out of these came·DC motors·with some gear reduction...these are the ones I'm working with now
Thanks again for the inputs!
-Grant
Basic Discovery Kit (newbie)
