How to expand VGA Rows and column ?
·Hi, I was wounding if there is any way to expand the VGA resolution on the VGA object? I would like to do this if possible without using a different object.
Thank you,
CameronM
Post Edited (CameronM) : 7/11/2010 4:19:03 AM GMT
Thank you,
CameronM
If you're just interested in text, have a look at the higher resolution drivers in the Object Exchange. They work mostly by using 2 or 4 cogs to handle 4 or 2 scan lines each while one of the cogs is outputting the scan line information.
Post Edited (Mike Green) : 7/11/2010 1:45:46 AM GMT
Thank you,
CameronM
Here is a link to the manual if i did not provide enough info, page 8 has the specs.
ftp://ftp.work.acer-euro.com/monitor/lcd/manuals/al1916w/user/English.pdf
I have one other question for the VGA out it is recommended that you use 240 Ohm resistor would I be able to get away with using a 220 Ohm resistor in place?
Thank You,
CameronM
Post Edited (CameronM) : 7/11/2010 7:08:35 AM GMT
