crystal load capacitance and the Propeller
How does the crystal load capacitance work with the Propeller? According to the datasheet the capacitance the propeller uses when in XTAL1 mode is 36pF. The crystal on parallax's website is 20pF and the one I use is 18pF. So how does this all work together?
I find the 18pF capacitor seems to run a bit slow (maybe 0.05%) and I am wondering if that is because of capacitive load I am using or what? Is there some hardware way to fix that? Maybe series capacitors or parallel? Or do I just need to measure what it is producing and put that in as the crystal speed instead of 5MHz?
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Some of my objects:
The frequency could be adjusted by using a small trimmer capacitor from one side of the crystal to ground if the error is in one direction, or a tunable inductor in series with the crystal, if it is in the other direction. Or, you could measure the frequency, and compensate for the error in your software.
Leon Heller
Amateur radio callsign: G1HSM
Clock Mode Setting Constant1
XO Resistance2
XI/XO Capacitance2
Description
With the usual Pierce oscillator configuration, the feedback capacitors (internal on the Propeller) are effectively in series and need to be roughly twice the load capacitor value. Strays need to be accounted for, which is where the 36 pF comes from.
Leon Heller
http://forums.parallax.com/showthread.php?p=816552
