Regulating Voltage
Hello,
I am looking to hook up a custom·h-bridge to my propeller to control a motor but I am having problems regulating my power supply for the 12V motor (pulls about 3amp).
At the moment I have a 16.5 volt Lipo battery·and a 7812 12 VDC voltage regulator, however the current limit for this regulator·is a bit too small at 1 amp.· I was wondering if three of these voltage regulators in parallel would give me a 3 amp limit (following resistor rules) which would be sufficient for my motor?· If this would not work could you guys please list out some other ways to regulate a 16.5 volt power supply to 12 volts at 3 amps. a transformer maybe?
Thank you
Technic-R-C
Thank you
Technic-R-C
But Phil is right, a little higher voltage won't hurt.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
I finally found a circuit that would boost my current limit to 3 amps by putting three voltage regulators in parallel.· Although I do·like the other alternatives.
Regards
Technic-R-C
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
