Where to hookup the antistatic wrist strap on board a boat?
electrosys
Hello all,
Like most of you, I use an antistatic wrist stap to prevent eletrostatic discharge (ESD) ruin the ICs and eletronic circuits. The problem is that I live onboard a boat and don't really know where to connect/ground my wrist strop! As for now·I have connected my wrist strop to the boat's mast steel wires, but I'm not really sure that aluminium mast and the steel wires are good enough to prevent an static·discharge, any idea where or how I could ground my wirst strop on board?
BTW... my Dad invented that grounding strap!!! He actually invented it for something totally different, a heart rate monitor, but also wrote in the patent appliation as a side note that it could also be used as a ground strap to protect delicate electronic CMOS equipment when it was first being experimented with.
Bill
Setting that aside, the point of a "real" ESD system is to make sure that all components and user are at the same "ground level".· If that level is "earth ground" or 1000 volts above "earth ground", it really doesn't matter, as long as everything and everyone is at the same level.
So, on your boat, if there is a 120 volt system, you could use that·"ground", or use·the negative·(usually black)·side of the 12/24 volt system.· The important thing is to have all items (chasis, anti-static mats, wrist straps, etc.) tied to the same point/bus.
Be careful of using just the case of a piece of equipment.· Sometimes the cases of marine equipment are very much isolated from what's inside to protect from water, moisture, algae, vibration/bouncing,·etc.·· Some of this stuff is not built like "normal" electronics in many ways.· I seem to recall someone saying that water and electricity don't mix...
For others reading, in terms of "marine" (meaning fresh and salt water) equipment, you see a complete spectrum of "quality" ranging from a bilge pump that may, or may not, last a single season to some very "exotically" packaged equipment that could be submerged 100s of feet in salt water, and come out fine.· Price is also not always the determining factor (on either end).· Lots of neat surprises to be had...
John R.
Click here to see my Nomad Build Log
Post Edited (John R.) : 7/9/2010 2:22:36 PM GMT
How do you/can you use these things as a heart monitor?
John R.
John R.
OMG I have used the straps only with my 3 lead ECG /wrist /wrist / leg monitor ..
I figured they were not sticky like pads . and not as hard to find..
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Post Edited (Peter KG6LSE) : 7/10/2010 5:13:53 AM GMT
Not all boats have earth plates as such. However, the engine will be grounded and that in turn will be grounded to the sea via either a leg or prop shaft.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
When he started working on the heart rate monitor using CMOS, he also realized they could use the same system as a sensor because of they way it worked. The wriststrap was used as a pickup lead for a signal that was transmitted to some other part of the body, usually the chest. Modern excerise equipment uses this type of device now, for example most high end wristwatch heart rate monitors also come with a chest strap. Some are even built into clothes. His idea was specifically for battlefield scenerios, where it might be impossible, impractical or uncomfortable to attach leads elsewhere.
Bill
Do a web search for "wiki Van de Graaff" for details
Searider
I must have been asleep!
Bill
As said above, just make sure your strap(you) and the work piece are strapped to the same thing. Something big and metal is good. Something that is big and metal and is also electrically common to the water is great.
