Programming a Stamp to effectively Reset
Hi Team,
I'm looking for a way to have a button press sequence cause a reset on a BS2p40.
I have Aux pin 15 available. I was thinking that if I connect it to the reset pin with a .1 cap, and set it high at startup, then taking it low would pull the reset pin low long enough to cause a reset.
Anyone ever tried this, or have any ideas?
Thanks in advance,
Darlene
Post Edited (Geekgirl) : 7/9/2010 3:36:28 AM GMT
Thanks in advance,
Darlene
I can see using the 220 ohm resistor instead of a cap. Since it's pulled up internally with a 4.7k, it could even be 1k resistor, as it only needs to drop the reset pin below 4.2V
Thanks Mike,
Darlene
If you know the answer. Why ask the question ?
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
Trust me. People often ask questions when they really know the answer. They're unsure and would like confirmation, but sometimes are uncomfortable stating what they believe is true and asking for confirmation. Sometimes they have two or more possible answers and are not sure which is correct or if both are right. Sometimes they would also like an explanation.
Why implement a far less than optimal solution, when better options are often here for the asking.
I'd rather fell stupid asking and finding I did have a good answer, than really stupid for not askingf at all.
Darlene
Mike hit the nail on the head.
