Basic Stamp Educational Board Cannot Run without USB cable
Hi All,
I am an undergraduate from a university in Singapore.
My project team is currently working on th pole balancing robot. We are using the Education Development Board (USB).
It can't seem to run without the USB cable. Anyone knows what's the issue with this? Software or hardware?
Also does anyone know what the rubber wheels used in toy kits are generally made of? What is the poison ratio, youngs modulus and density?
Thanks.
Murtaza.
Thanks.
Murtaza.
Not being able to run without the USB cable plugged in is either a power problem, or a grounding problem -- grounding usually.
Parallax Engineering
Phooey, you beat me to it....
The wheels could really be anything. ABS will be relatively hard, it could be acetal, Polypropylene of HDPE/UHMW if they are somewhat gummy feeling, HDPE/UHMW if gummy feeling, but rigid. Phenolic, Nylon......
My guess would be HDPE for the wheels if they're plastic.... If it's rubber like you say, I dunno much about that. Neoprene? if it's soft.
"puff"...... Smile, there went another one.
Post Edited (Spiral_72) : 7/8/2010 8:28:35 PM GMT
Did you reply in the wrong thread?
Thanks for all the replies.
I solved the issue of not being to operate without the USB cable. The cable making the common ground between the board and motor driver board was lost. When I reconnected the grounding, then it was all good.
The tyres that I am using are hard and not sticky. How would I know if they are plastic or rubber? I think it is rubber. I am not so sure.
Murtaza.
MAGGOTS!
No sir
Without any disrespect intended.... what does it matter? You might be able to arrive at some friction coefficient but testing, but it still doesn't seem to matter much. I guess I don't know what you're doing with the wheels either.
If the wheels are injection molded (is thin wall with a cavity inside and probably webs for structure) I'd say most surely plastic of some type. If they are solid with a hole bored through or somehow sandwiched by a hub, I'd have to vote a hard rubber
I'd say try em' and if you need more traction, add rubber bands around it or swap the wheels out for something else. The grocery stores sometimes use ~3/4" blue rubber bands on brocolli and the like that would probably go around wheels up to about..... ummmmmm.... 2.5" dia or maybe 3"??
