Prop Plug
What does it mean when your prop plug does not flash more then once when you plug it in?
I've checked the battery and the USB line.
I have a Propeller Education Kit, and I'm running Windows 7.
I do not see anything listed in my devise manager for the prop plug.
The indicator lights only flash once when it is plugged in.
Thank you.
Thank you.
I think you are asking for help troubleshooting a prop plug. If that is the case you need to be powering the prop plug with 5V for it to work properly.
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
If you're not seeing the Prop Plug as a USB port, that's a fairly likely culprit.
>>insert slamming head against desk sound here.<<
thanks for your advice.
