Prop plug.....
Hey all. I was taking my prop plug out of a breadboard that i had ,and to my surprise, the pins of the prop plug sheared off. When i tried to solder wires back on to it, the·pads came off. Why is the prop plug so fragile? Is there something that i can rig up/ buy to program the Propeller if it ever happens again? I was about to test my new robot when the thing broke and now i gotta wait a couple of days for the new one to arrive.·Parallax should make the prop plug a lot more sturdier....
Propeller + Picaxe = Romeo & Juliet
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
I think the Prop Plug has a design flaw - mine broke in exactly the same way. Luckily, I managed to solder a new connector to it.
I'd recoomend anyone using a Prop Plug to use it with a cable rather than plugging it straight onto a board - the pins are very feeble and are obviously not designed to take any stress.
Ross.
Catalina - a FREE C compiler for the Propeller - see Catalina
If so, then you could use kynar wires (the fine wire wrap single core kind) to solder a fine wires to the pins where the broken tracks lead. You could then glue (hot glue) the connector back and then use a cable as I described.
Also, the schematic for making a serial connection to the propeller is in the Propeller datasheet.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
