Compatibility of IR Sensor with Propeller
In the Parallax Process Control Manual (page 117 - attached) a QRB1114 IR Sensor (spec sheet attached) was used in a 5V BS2 configuration. I would like to use the same sensor in a similar configuration in the Propeller Prof Development Board but I wasn't certain about the 5V to 3V compatibility. If (??) the anode and cathode of the IR LED can be connected to the +5V and -5V rails, and the 10K resistor and emitter of the photo-transistor can be connected to the +5V and -5V rails respectively as they are in the BS2, how can the correct value of the resistor (currently 220 ohm) leading into a Propeller IO port be calculated?
In advance, thank you.
