Help with table access
I have the followiing code:
I cannot undestand whi I can access the second table with no problems, while the first table can only be accessed using the long method. They look the same, but the do not behave the same way. Could you please help me?
Massimo
Massimo
VAR ''Setup Variables for this demo
long A_lat,A_long
long B_lat,B_long
PUB Main | tmp ,i
pst.start(9600)
repeat
pst.char(0)
pst.str(string("1->2:"))
A_lat:=long[noparse][[/noparse]@punti_lat]
B_lat:=punti_lat
A_long:=punti_long
B_long:=punti_long
pst.char(13)
scrivi_pst
waitcnt(cnt+clkfreq)
PUB scrivi_pst
pst.str(string("Lat_A "))
pst.dec(A_lat)
pst.char(13)
pst.str(string("Lat_B "))
pst.dec(B_lat)
pst.char(13)
pst.str(string("Long_A "))
pst.dec(A_long)
pst.char(13)
pst.str(string("Long_B "))
pst.dec(B_long)
dat
punti_lat
long 0
long 271010000
long 271009167
long 271008333
long 271008750
long 271010333
long 271010167
punti_long
long 0
long 61001667
long 61005000
long 61003333
long 61001833
long 61002917
long 61004833
The compiler uses the "long" to tell it what size array element to use and how it's aligned..
I guessed the alignement can be on the next line.
Is the compiler aligning the second table because I have a former with long declared?
Massimo
If the table comes from a spreadsheet to have it aligned will require a little bit of regexp stuff..
Thanks.
dat punti_lat long 0 long 271010000 long 271009167 long 271008333 long 271008750 long 271010333 long 271010167 punti_long long 0 long 61001667 long 61005000 long 61003333 long 61001833 long 61002917 long 61004833
Post Edited (max72) : 7/7/2010 3:35:22 PM GMT
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
Safety Tip: Life is as good as YOU think it is!
I was just lazy...
Massimo
I think what's happening is that the "DAT begins a section that could be aligned in any way (bytes, words, or longs). The label "punti_lat" has no alignment information associated with it and causes an error while the label "punti_long" follows a "long" directive that establishes long alignment at that point. I don't think this is a good way to do things, but it's easily fixed by always starting a table like this with byte, word, or long and no operands like "punti_lat long".
I misunderstood the alignement point.
It's amazing how a couple of code lines written down to test another function can bring problems and better understanding...
Massimo
