Wallpack and relay and ???
jefm
This is electronics 101 stuff but someone asked me and i wanted to be sure...
Project:
A smart 110vac outlet will power up a wallpack. 12v, 500ma or whatever we can find, it's irrelevent. The wallpack runs a small relay, 1amp or less. That's basically it, the relay contacts will dis/connect another piece of equipment that i've already worked out.
Should I put a 10 ohm resistor or something in the coil circuit to reduce current usage? I just worried if the relay or wallpack will get messed up if it's doing an almost short circuit for days on end. I played around with some resistors here and can get to around 40 ohm before the relay quits contacting. Thanks for any help!
Project:
Going to recommend a dozen or so ohms in line. It's easy enough to figure out when the coil stalls without a meter, and i figure too little resistance will be better then none at all.
And relays are designed to be momentarily on, or on for long periods of time. One term used for rated to be on for long periods of time is "Continuous Duty" relay. I seem to recall other terms used, but can't think of them now.
Another set of terms they use is "definite purpose" "contactor" (relay). The idea behind this is if the part fails, it should only be replaced with the same part.
Also relays which are on for long periods of time·can be quite hot. Might want to enclose in a well ventilated fire-proof box.
Look at the "datasheet" for the relay and this will show coil current/amperage as well as the "duty cycle/rating". Here is an example...
http://www1.futureelectronics.com/doc/TYCO%20ELECTRONICS/3-1393237-1.pdf
FYI -·All about·relay contacts, "Relay Contact Life"...
http://relays.tycoelectronics.com/appnotes/app_pdfs/13c3236.pdf
