play wav file from SD card — Parallax Forums
shmowshmow Posts: 109
edited 2010-07-06 21:38 in Propeller 1
Hey All,
I purchased the SD adapter board and have been trying to play a WAV. file.
I've found a sample code (excellent and thorough - http://www.instructables.com/id/Make-a-Talking-Clock/?download=pdf); but it's somewhat complicated for my little brain to decipher.
If you look at the main portion of the enclosed program then you'll see a simple sub-routine call with it's related commands to play files.
However, a big fat nothing happens.
I've tried all sorts of things - I've even flipped the SD card thinking I've got it in the slot upside down.
No luck.
Is there any help out there?
Shmow
' Propeller Pins SD card Pins
' 3.3v
'      10k res
' p0 ───────────┻─┼─┼─┼─┼────────── do
' p1 ─────────────┻─┼─┼─┼────────── clk
' p2 ───────────────┻─┼─┼────────── di
' p3 ─────────────────┻─┼────────── cs
' └────────── irq
' p7 ──────────────── + [noparse][[/noparse]speaker] - ─────┐
' 47µF cap GND
con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
bufferlen = 800
obj
wpl : "WavePlayerSdAccess"
var
byte ledcolor
byte newhours
byte blinkflip
byte buff[noparse][[/noparse]bufferlen]
long stack[noparse][[/noparse]300]
byte alarmhour
byte alarmmin
byte alarmstat
byte secblinker
byte oldsec
pub main | b ' main program loop
cognew(announcer, @stack)
repeat
announcer
waitcnt(clkfreq+cnt)
pub announcer | currhr, currmin, currsec ' checks if esc has been hit and annouces time
wpl.start(0, 5, 4, @buff, bufferLen)
repeat
wpl.playwave(string("morn.wav"))
wpl.playwave(string("standard.wav"))
playhours(14)
playmins(21)
playsecs(41)
pri playhours(hrs) ' announce hours
IF (hrs <13)
playnumber(hrs)
ELSE
playnumber(hrs -12)
pri playmins(minns) ' announce minutes
IF (minns == 0)
wpl.playwave(string("exact.wav"))
else
IF (minns < 10)
playnumber(0)
playnumber(minns)
wpl.playwave(string("and.wav"))
pri playsecs(secs) ' announce seconds
playnumber(secs)
wpl.playwave(string("secs.wav"))
wpl.playwave(string("beep.wav"))
pri playnumber(number) | tendig, onedig ' generic routine to announce numbers
if (number < 20)
player(number)
ELSE
tendig := number / 10
tendig := tendig *10
onedig := number - tendig
player(tendig)
IF (onedig <> 0)
player(onedig)
pri player(number) | i
IF (number < 20)
wpl.playwave(@shortfiles[noparse][[/noparse]7 * number])
ELSE
i := number / 10
wpl.playwave(@longfiles[noparse][[/noparse]7 * i])
DAT
shortfiles byte "00.wav",0,"01.wav",0,"02.wav",0,"03.wav",0,"04.wav",0,"05.wav",0,"06.wav",0,"07.wav",0,"08.wav",0,"09.wav",0,"10.wav",0,"11.wav",0,"12.wav",0,"13.wav",0,"14.wav",0,"15.wav",0,"16.wav",0,"17.wav",0,"18.wav",0,"19.wav",0
longfiles byte "00.wav",0,"10.wav",0,"20.wav",0,"30.wav",0,"40.wav",0,"50.wav",0
    edited 2010-07-06 13:37
    You might be chasing two project at once.. Always tricky..
    Cross check your SD setup with something like FemtoBASIC or PropDOS which are known to work across a variety of configurations.
    (Don't be afraid to switch out your SD card itself in this test.)
    Once you verify that your hardware is working correctly, then turn your attention back to your WAVplayer code.
    You might also find the Propeller Cookbook, page 5 useful.
    OBC
    Propeller Feature Projects: PropellerPowered.com
    Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
    Post Edited (Oldbitcollector) : 7/6/2010 1:44:32 PM GMT
  • shmowshmow Posts: 109
    edited 2010-07-06 13:45
    Hey OBC,
    this PropDOS, what application do I open it with? I've discovered it's not Propeller Tool.
    Shmow
    edited 2010-07-06 13:48
    Uh oh! I need the combo keyboard and video - eegads!
    You'll need to rename the file with a .zip extension as the forum didn't like the upload.
    Then you should be able to extract and use it with the Propeller tool.
    OBC
    edited 2010-07-06 13:50
    Hi Shmow,
    one thing that will help forum members help you is for you to place your code between two "code tags". They look like this except you need to take out the spaces
    [noparse][[/noparse] code ]
    [noparse][[/noparse] / code ]
      That way the indentation
         of your code
           will be preserved
    edited 2010-07-06 13:52
    No video or keyboard huh? Try this instead..
    You'll have to uncomment the sections you want to activate in the code.. Don't worry it's well documented.
    OBC
    edited 2010-07-06 13:54
    oops, sorry.
    I trust this is better.
    '                                      3.3v
    '                                        &#61463; &#61463; &#61463; &#61463; &#61463;
    '                             &#61628; &#61628; &#61628; &#61628; &#61628; 10k
    '   p0 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9532;&#9472;&#9532;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; do
    '   p1 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9532;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; clk
    '   p2 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; di
    '   p3 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; cs
    '                                              &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; irq
    '&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;
    '   p7 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#61611;&#9472;&#9472;&#9472;&#9472;&#9472; + [noparse][[/noparse]speaker] - &#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    '        &#61464;
    '                          47µF cap                                 GND
    con
      bufferlen = 800
    obj
    var
    byte ledcolor
    byte newhours
    byte blinkflip
    byte alarmhour
    byte alarmmin
    byte alarmstat
    byte secblinker
    byte oldsec
      repeat
         announcer
      repeat
          playhours(14)
          playmins(21)
          playsecs(41)
        IF (hrs <13)
          playnumber(hrs)
        ELSE
          playnumber(hrs -12)
    IF (minns == 0)
    else
      IF (minns < 10)
        playnumber(0)
      playnumber(minns)
        playnumber(secs)
    if (number < 20)
      player(number)
    ELSE
      player(tendig)
      IF (onedig <> 0)
        player(onedig)
    IF (number < 20)
    ELSE
      i := number / 10
    DAT
    edited 2010-07-06 13:55
    must be the heat wave here...
    here's a better version:
    '                   3.3v
    '                                           &#61464;
    '             47µF cap                     GND
    con
      bufferlen = 800
    obj
    var
    byte ledcolor
    byte newhours
    byte blinkflip
    byte alarmhour
    byte alarmmin
    byte alarmstat
    byte secblinker
    byte oldsec
      repeat
         announcer
      repeat
          playhours(14)
          playmins(21)
          playsecs(41)
        IF (hrs <13)
          playnumber(hrs)
        ELSE
          playnumber(hrs -12)
    IF (minns == 0)
    else
      IF (minns < 10)
        playnumber(0)
      playnumber(minns)
        playnumber(secs)
    if (number < 20)
      player(number)
    ELSE
      player(tendig)
      IF (onedig <> 0)
        player(onedig)
    IF (number < 20)
    ELSE
      i := number / 10
    DAT
    edited 2010-07-06 14:00
    OBC,
    thanks I'm all over it like stink on a skunk.
    Shmow
    edited 2010-07-06 14:05
    OBC,
    what is PST? Can I use hyper terminal instead?
    Shmow
    edited 2010-07-06 14:17
    Yes, I'm using hyper terminal.
    Thanks a'plenty.
  • LeonLeon Posts: 7,620
    edited 2010-07-06 14:18
    It's the Parallax terminal program, it's a lot better than HyperTerminal. You can download it from the Parallax web site (Propeller Downloads).
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-07-06 14:21
    Thanks Leon.
    edited 2010-07-06 14:36
    I have the PST connected.
    After running a test, it states that: "SD card expected..."
    I know this card works because I've used a separate card reader on it successfully.
    I've checked the connections of the pins and they are correct and true.
    Could I have damaged the SD card adapter while soldering it together - specifically the card reader?
  • RaymanRayman Posts: 15,701
    edited 2010-07-06 15:16
    Are you trying to drive a speaker directly from a Prop pin?
    You are using amplified speakers, right?
    My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
    My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
    edited 2010-07-06 15:17
    PS: I have some wave players in OBEX you might try. One of them doesn't need the SD card...
    edited 2010-07-06 16:02
    Hey Rayman,
    ultimately, the file will be fed to a "line out" of an amplifier.
    Currently, I have an emic, and I want to replace it with the SD/WAV design.
    That's great for the offer! I do want to keep the SD option.
    It looks like I'd use your sysdep_demo_ser.spin.
    Shmow
    edited 2010-07-06 16:09
    shmow said...
    Anything is possible.. Which card reader are you using?
    The "SD card expected..." message means that the card failed to mount. double check pins settings in the CON section.
    Just for giggles.. Have you tried a different card?
    OBC
    edited 2010-07-06 16:12
    Yes on both counts - checked the con settings and used another card.
    This hill is getting steeper, but I bet the view will be worth it.
    edited 2010-07-06 16:15
    Yes, conquering SD is truly worthwhile..
    You didn't answer which SD interface you were using..
    Any chance that you have a spare molex (or equiv) SD connector you could wire up?
    I've manged to run many SD setups without the pull-up resistors with simply the four required wires
    directly from the Propeller to the SD card. Follow the example given in page 5 of the Cookbook link I gave you earlier.
    The only problem I've ever run into was a Sparkfun SD/pcb that I ordered earily on, once I shifted to other options
    SD has been smooth sailing.
    OBC
    edited 2010-07-06 16:22
    the reader is the one which came with the parallax SD Card Adapter (product #32313)
    it's the 3M product.
    edited 2010-07-06 16:29
    Time to whip out a meter and check the connections.
    I'd check from the rear of the card to the pin. Don't worry about CD and WP at this point.
    OBC
    edited 2010-07-06 16:34
    I've done that - I'm beginning to think I cooked the reader.
    I used a hot air solder to make the connections and there was some damage on the sides where the two large "feet" are to solder.
    I figured it was just cosmetic; perhaps I'm mistaken.
    edited 2010-07-06 16:43
    Ouch!
    Time to whip out four paperclips and a piece of perf-board..
    Someone unfolded the paper clips to one bend, inserted them through some perfboard and soldered to the back side.
    Slid the SD card between the perfboard and the paperclips.. If I can find the photo you'll get a chuckle.
    It really isn't much more than four I/O connections and Vss/Vdd
    OBC
    edited 2010-07-06 16:44
    on the reader, I checked the isolation of between the GND pin and the CD pin.
    There's a short there (or they're connected for a reason).
    Those two pins are the small pair right on the end.
    Should I isolate them?
    edited 2010-07-06 16:48
    It's the little, tin guard or fender between the GND and CD; I've soldered the fender to CD.
    edited 2010-07-06 17:27
    I have the reader working!!!
    The problem was the card?!!
    I pulled another card from my camera and used it.
    Prior to that I was using a pair of cards that have been
    sitting in my desk for years.
    Now the next step is to get my sample code to work.
    'Cause I'm getting no sound or anything.
    edited 2010-07-06 18:47
    Most Excellent!
    Fall back to Rayman's WAV player code from OBEX. (I think he gave you a link somewhere in this thread.)
    That'll help you sort out the other side of the issue.. [noparse]:)[/noparse]
    OBC
    edited 2010-07-06 20:50
    Hey All,
    now that I have some kind of communication between the prop and the SD reader,
    I'm trying to get the prop to send the WAV. file (MORN.WAV) to the little speaker.
    I've looked at several examples and I've had no luck.
    My oscilloscope shows there is a signal going out to the speaker from pin 7, but nothing is heard.
    Does anyone have any suggestions?
    Shmow
    '                     3.3v
    '                 &#61628; &#61628; &#61628; 10k
    '   p0 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9532;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; do
    '   p1 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; clk
    '   p2 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9532;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; di
    '   p3 &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9531;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; cs
    '                                           &#61464;
    '             47µF cap                     GND
    con
      bufferlen = 800
    obj
    var
      repeat
         announcer
         waitcnt(clkfreq*4+cnt)
    wpl.start(0, 7, 7, @buff, bufferLen)
          playsecs(41)
        playnumber(secs)
    if (number < 20)
      player(number)
    ELSE
      player(tendig)
      IF (onedig <> 0)
        player(onedig)
    DAT
    I see a "speaker" referenced. An amplified speaker? I doubt you'll get much signal to power anything at standard 8ohms without some help.
    OBC
