Ir Remote Control Problems
I have a led wired to pin 3 on my Bs2 when I push 1 on my Ir remote the led turns on yet when I push 3 the led does not turn off. Any Ideas?
[noparse][[/noparse] Title ]
' Ir Remote Application - IrRemoteButtonDisplay.bs2
' Process incoming SONY remote signals and display the corresponding button
' in the Debug Terminal.
' {$STAMP BS2} ' BS2, 2sx, 2e, 2p, or 2pe
' {$PBASIC 2.5}
[noparse][[/noparse] Revision History ]
' V1.0 - Supports most SONY TV and VCR control buttons.
' Supports BASIC Stamp 2, 2SX, 2e, 2p, and 2pe modules.
[noparse][[/noparse] I/O Definitions ]
' SONY TV IR remote declaration - input receives from IR detector
IrDet PIN 9
value VAR WORD ' I/O pin to IR detector output
[noparse][[/noparse] Constants ]
' Pulse duration constants for SONY remote.
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE ' PULSE durations
ThresholdStart CON 1000 ' Message rest vs. data rest
ThresholdEdge CON 300 ' Binary 1 vs. 0 for RCTIME
OverStart CON 1125 ' Start pulse max
UnderStart CON 675 ' Start pulse min
#CASE BS2P, BS2SX
ThresholdStart CON 2400 ' Binary 1 vs. start pulse
ThresholdPulse CON 500 * 5 / 2 ' Binary 1 vs. 0 for PULSIN
#CASE #ELSE
#ERROR This BASIC Stamp NOT supported.
#ENDSELECT
' SONY TV IR remote constants for non-keypad buttons
Enter CON 11
ChUp CON 16
ChDn CON 17
VolUp CON 18
VolDn CON 19
Mute CON 20
Power CON 21
TvLast CON 59 ' AKA PREV CH
' SONY VCR IR remote constants
' IMPORTANT: Before you can make use of these constants, you must
' also follow the universal remote instructions to set your remote
' to control a SONY VCR. Not all remote codes work, so you may have to
' test several.
VcrStop CON 24
VcrPause CON 25
VcrPlay CON 26
VcrRewind CON 27
VcrFastForward CON 28
VcrRecord CON 29
' Function keys
FnSleep CON 54
FnMenu CON 96
[noparse][[/noparse] Variables ]
' SONY TV IR remote variables
irPulse VAR WORD ' Stores pulse widths
remotecode VAR BYTE ' Stores remote code
[noparse][[/noparse] Initialization ]
DEBUG "Press/release remote buttons..."
[noparse][[/noparse] Main Routine ]
' Replace this button testing DO...LOOP with your own code.
DO ' Main DO...LOOP
DO
DEBUG CR, CR, "Type value from", CR, "0 to 65535,", CR, "then press ENTER", CR, CR
value = 0
remotecode = 0
DO
value = value * 10 + remotecode
DO
GOSUB Get_Ir_Remote_Code
IF (remotecode > 9) AND (remotecode <> Enter) THEN
DEBUG "Use digit keys or ENTER", CR
PAUSE 300
ELSE
DEBUG "You pressed: "
IF remotecode = Enter THEN
DEBUG "Enter", CR
ELSE
DEBUG DEC remotecode, CR
ENDIF
PAUSE 300
ENDIF
IF value = 1 THEN
HIGH 3
IF value = 3 THEN
LOW 3
ENDIF
ENDIF
LOOP UNTIL (remotecode < 10) OR (remotecode = Enter)
LOOP UNTIL (remotecode = Enter)
DEBUG ? value, CR, "Ready for next value...", CR
LOOP
LOOP
' Repeat main DO...LOOP
[noparse][[/noparse] Subroutine - Get_Ir_Remote_Code ]
' SONY TV IR remote subroutine loads the remote code into the
' remotecode variable.
Get_Ir_Remote_Code:
remotecode = 0
#SELECT $STAMP
' Wait for resting state between messages to end.
DO
RCTIME IrDet, 1, irPulse
LOOP UNTIL irPulse > ThresholdStart
' Measure start pulse. If out of range, then retry at
' Get_Ir_Remote_Code label.
RCTIME 9, 0, irPulse
IF irPulse > OverStart OR irPulse < UnderStart THEN Get_Ir_Remote_Code
' Get data bit pulses.
RCTIME IrDet, 0, irPulse
IF irPulse > ThresholdEdge THEN remotecode.BIT0 = 1
IF irPulse > ThresholdEdge THEN remotecode.BIT1 = 1
IF irPulse > ThresholdEdge THEN remotecode.BIT2 = 1
IF irPulse > ThresholdEdge THEN remotecode.BIT3 = 1
IF irPulse > ThresholdEdge THEN remotecode.BIT4 = 1
IF irPulse > ThresholdEdge THEN remotecode.BIT5 = 1
IF irPulse > ThresholdEdge THEN remotecode.BIT6 = 1
#CASE BS2SX, BS2P
DO ' Wait for start pulse.
PULSIN IrDet, 0, irPulse
PULSIN IrDet, 0, irPulse ' Get data pulses.
IF irPulse > ThresholdPulse THEN remotecode.BIT0 = 1
IF irPulse > ThresholdPulse THEN remotecode.BIT1 = 1
IF irPulse > ThresholdPulse THEN remotecode.BIT2 = 1
IF irPulse > ThresholdPulse THEN remotecode.BIT3 = 1
IF irPulse > ThresholdPulse THEN remotecode.BIT4 = 1
IF irPulse > ThresholdPulse THEN remotecode.BIT5 = 1
IF irPulse > ThresholdPulse THEN remotecode.BIT6 = 1
#CASE #ELSE
#ERROR "BASIC Stamp version not supported by this program."
#ENDSELECT
' Map digit keys to actual values.
IF (remotecode < 10) THEN remotecode = remotecode + 1
IF (remotecode = 10) THEN remotecode = 0
RETURN
' {$PBASIC 2.5}
IrDet PIN 9
#SELECT $STAMP
#CASE BS2P, BS2SX
#CASE #ELSE
#ENDSELECT
Enter CON 11
ChUp CON 16
ChDn CON 17
VolUp CON 18
VolDn CON 19
Mute CON 20
Power CON 21
' test several.
VcrStop CON 24
VcrPause CON 25
VcrPlay CON 26
VcrRewind CON 27
VcrRecord CON 29
' Function keys
FnSleep CON 54
FnMenu CON 96
DO ' Main DO...LOOP
DO
value = 0
remotecode = 0
DO
DO
PAUSE 300
ELSE
DEBUG "Enter", CR
ELSE
ENDIF
PAUSE 300
ENDIF
IF value = 1 THEN
HIGH 3
IF value = 3 THEN
LOW 3
ENDIF
ENDIF
LOOP
LOOP
Get_Ir_Remote_Code:
remotecode = 0
#SELECT $STAMP
DO
#CASE BS2SX, BS2P
#CASE #ELSE
#ENDSELECT
RETURN
Not sure how you are expecting the variable value to be different than remotecode?
Try this:
DEBUG dec value' just see what value is
IF remotecode = 1 THEN HIGH 3' changed from 'value'
IF remotecode = 3 THEN LOW 3' changed from 'value'
should be:
or:
