SPIN's True Randomness can't be BUSTed — Parallax Forums
cessnapilotcessnapilot Posts: 182
edited 2010-07-05 15:38 in Propeller 1
A new object has been just appeared in OBEX containing a Battery of Useful Stat Tests (BUST). With this object one can test & verify any random number generator. See
http://forums.parallax.com/showthread.php?p=839776
In the object the True Random Number Generator of SPIN_TrigPack is checked. This is written (only) in SPIN and gives you different random sequences after each reboot. If only one can explain that...
Of course, you can test any other RNG with this object. Randomness is all around. You have not to model it, just use it.
Cheers,
Istvan
Intentionally Left Blank
  • LeonLeon Posts: 7,620
    edited 2010-07-03 15:48
    It doesn't actually use a true RNG!
    Leon Heller
    Amateur radio callsign: G1HSM
  • cessnapilotcessnapilot Posts: 182
    edited 2010-07-03 16:13
    Please Leon, explain me why not.
    1. It gives a different sequence after each reboot.
    2. Statistical tests verify it. (More or less independently of·any subjectivity)
    3. You can't predict it. (Me, too)
    4. It has practically the same statistical parameters as one with TrueRandom
    Anyway, thank you for the first opinion to that TRNG in SPIN. I really appreciate it.
    Cheers
    Istvan
    edited 2010-07-03 16:38
    Random numbers can't be generated by a computer program.
    This is a true RNG:
    www.idquantique.com/true-random-number-generator/products-overview.html
    Leon Heller
  • heaterheater Posts: 3,370
    edited 2010-07-03 16:53
    Leon: "Random numbers can't be generated by a computer program."
    Bah Humbug ! My programs do it all the time [noparse]:)[/noparse]
    Anyway are we talking about the Spin true random number generator that uses jitter of the PPL to get entropy, which is then not just a computer program?. Or something else?
    edited 2010-07-03 17:02
    BUST doesn't use the PLL, I had a look through the code. PLL jitter won't generate true RNGs anyway, as it is affected by factors like temperature and voltage, unlike quantum events.
    Leon Heller
  • AleAle Posts: 2,363
    edited 2010-07-03 17:32
    Leon,
    but can you reproduce it with a second Prop (the PLL-jitter generator) ? if not... it is random enough [noparse]:)[/noparse]
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
    edited 2010-07-03 17:38
    I once read a fiction book that told the story of an autistic person reaching that normal human state. During that awakening, the concept of "enough" was shown in an interesting way. To the autistic, the floor was not flat. To the ordinary person, it's flat enough. That layer of abstraction helps us to function every day, where it would otherwise be madness to focus on the little variances seen everywhere.
    Random enough.
    8x8 color 80 Column NTSC Text Object
    Wondering how to set tile colors in the graphics_demo.spin?
    Safety Tip: Life is as good as YOU think it is!
    edited 2010-07-03 17:40
    Random enough for what? It's application-dependent.
    Perhaps this thread should be titled "SPIN's True Randomness can't be trusted". smile.gif
    Leon Heller
    Post Edited (Leon) : 7/3/2010 6:11:06 PM GMT
    edited 2010-07-03 20:03
    That was my point. If it's even possible to come to some realization that something is actually random, it doesn't get us much in a lot of scenarios; thus, "random enough".
  • KeithEKeithE Posts: 957
    edited 2010-07-03 20:14
    Why can't you predict the output of this program? If I have a program that has several different pseudorandom number generators, and it picks one of these "randomly" and picks an initial state "randomly" then after some amount of time observing the outputs we should be able to predict future outputs. With a true random generator no amount of observation is going to assist you in predicting future outputs.
    edited 2010-07-04 01:42
    Temperature and voltage, are quantum events.
    edited 2010-07-04 02:38
    How can a temperature or a voltage be an event? A change in temperature or voltage can be an event, but they aren't relevant to something like the behaviour of a photon.
    Leon Heller
    Post Edited (Leon) : 7/4/2010 2:51:25 AM GMT
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2010-07-04 03:49
    Quantum physics aside... xkcd.com/221/
    edited 2010-07-04 03:58
    Kevin Wood: That's great. Every time I think of a random number it's 42 [noparse]:)[/noparse]
    edited 2010-07-04 10:02
    Gentlemen,
    Wether a sequence of numbers is random or not is not a question of taste.
    Neither has it any relation to its physical source, being quantum or not. The entropy origin of the numbers does not matter at all.
    Neither matters the creating device of the sequence, being a computer or not, or a sorcerer, dice or whatever.
    Randomness is a well defined mathematical property of a sequence of numbers. A property that can be investigated, analyzed and tested.
    Finicky mathematicians figured out long ago what properties of truly random sequence of numbers has.
    They invented test statistics based upon the ideal properties of randomness. Those people were really smart.
    A test statistic is used to put a numerical value on the departure from the ideal randomness. Thus the test statistic allows a judgement to be made about how far the actual data is from the theory.
    To use the test statistic a level of significance and a critical value must be determined. If the test statistic exceeds the critical value for a given test then the true randomness of the given· sample sequence is rejected.
    BUST uses 5% of statistical significance. Thus the probability of observing a test statistic value as or more extreme than the critical value is 0.05 for an ideal generator. In other words, even a perfect generator fails at 5% of the tests.
    What we should do with a given tested generator is to run·the tests infinite times and find out the probability of the actual fails. If that deviates from the expected value of the ideal generator, we can conclude that the tested generator is not perfect.
    But we do not have infinite time to do that. So, we accept a confidence interval, calculated from the average and standard deviation of the fails, to decide the question with a given confidence.
    And the result is not sure again. Such is life.
    A quantum effect based generator fails at 5% percent of BUST's tests, too. If not, it is not random, just a fake. Take care to avoid the snake-oil advertising of 'True Randomness'.
    Cheers,
    Istvan
    edited 2010-07-04 10:50
    Cessnapilot: "Whether a sequence of numbers is random or not is not a question of taste."
    I agree with you, but then again I don't.
    Consider a single "black box", that cannot be stopped, restarted or otherwise tampered with, generating a sequence of numbers by some unknown mechanism. It is impossible to definitively prove the randomness of that sequence. You can apply whatever statistical tests you like to that sequence and you will never conclusively prove it to be random or not. Perhaps it's taking it's entropy from a universe of quantum events but perhaps also it's just printing the tail end of the digits of pie which we have not and cannot get to yet but are not regarded as random.
    Cessnapilot: "Neither matters the creating device of the sequence, being a computer or not..."
    I have to take issue with that statement as well. By "computer" we generally mean some reliably functioning Turing machine. In this context running a program to generate some sequence. In that case the algorithm is the point. Once the algorithm is defined so is the sequence of numbers it can produce. Therefore the sequence cannot be random.
    In the face of all this what do we do?
    Well we cook up some statistical tests as you describe. But your description contains words such as "judgement" and "confidence" and concludes "And the result is not sure again".
    So it looks to me like a matter of taste as to when I give up trying.
    P.S. I love the Dilbert cartoon re:. randomness that you see here www.random.org/analysis/
    P.P.S. The Diehard battery of randomness tests was found to fail badly after some years of use. Wish I could find the link to that story.
    edited 2010-07-04 12:00
    Chaitin has written this nice article on randommess:
    www.cs.auckland.ac.nz/CDMTCS/chaitin/sciamer.html
    Not everyone agrees with him, of course.
    Statistical confidence levels are completely arbitrary. They can be avoided by using Bayesian techniques.
    The digits of PI (and any other transcendental number) probably are random:
    news.bbc.co.uk/1/hi/sci/tech/2146295.stm
    Physics ultimately depends on quantum events being random. Quantum-based RNGs are the best source of randomness we have. They are used extensively in research establishments.
    Leon Heller
    Post Edited (Leon) : 7/4/2010 12:12:43 PM GMT
    edited 2010-07-04 12:28
    Leon: "The digits of PI (and any other transcendental number) probably are random:"
    Here is where we are entering the world of semantics or even philosophy.
    The digits of PI, in my mind, for sure are not random. That is to say there is only one value of PI and every time you calculate it, down to however decimal places you can manage, it will be the same. As you said "Random numbers can't be generated by a computer program." Which is basically saying again that once the algorithm is defined so is the sequence. An algorithm cannot generate random numbers. PI is calculated from algorithms and therefore is not random.
    But the there is the looser definition of "random" is at work when people talk about the digits of PI. They are trying to say that there is no pattern, it never repeats etc etc. Basically the thing is we don't know what they are and cannot predict what they are except by calculating PI. To me this is not strictly random, just unknown. Of course there is a pattern to the digits of PI. It's the pattern you get when you perform the calculation of PI !!
    As for quantum events. I could argue from your statement that:
    a) Everything that ever happens is caused by quantum events.
    b) Therefore everything is a good source of randomness.
    edited 2010-07-04 12:36
    Perhaps it could be argued that an algorithm can generate random numbers, but would be impossible to do it with, say, a Turing machine, because a genuine Turing machine cannot be built.
    Everything ultimately depends on quantum events, but in our macro world, they are irrelevant. Everything isn't a good source of randomness, because something like noise in a resistor, which is sometimes used, depends on things like temperature. External effects like that don't influence events at the quantum level. That is why quantum RNGs are so popular. They aren't expensive, the Quantis unit costs €600, IIRC.
    Leon Heller
    edited 2010-07-04 12:38
    Leon: From the Chaitin article you linked to:
    "A series of numbers is random if the smallest algorithm capable of specifying it to a computer has about the same number of bits of information as the series itself"
    Using that definition of "random": Given that we can now calculate PI to billions of digits and I presume the programs that do it are not billions of bytes long then I conclude that PI is not random.
    edited 2010-07-04 12:39
    As I said, not everyone agrees with Chaitin.
    Anyway, I still maintain that the SPIN program mentioned doesn't generate true random numbers.
    Leon Heller
    Post Edited (Leon) : 7/4/2010 12:44:38 PM GMT
    edited 2010-07-04 13:00
    Leon: I think this thing about the superiority of quantum events as a source of entropy is looked at from slightly the wrong angle.
    My view is that thermal noise coming out of a resistor, opamp or other electronic device is a perfectly good source of randomness. As is some mechanical device tossing coins or throwing dice. There are many others.
    The problem seems to lie in how susceptible to outside tampering these things are. For example the signal from the thermal noise of your resistor might be swamped by some other electromagnetic interference getting into the system and "fixing" the result.
    In this respect radioactive decay, for example, cannot we assume be influenced. 241Am either decays emitting a gamma ray or it does not. and it does it when it feels like it at random.
    However that is of no use unless you can be sure that your entropy detector, detecting the decays, is also immune to outside interference and "fixing" or biasing the result.
    By the way, quantum events are not always so disorganized, the red light of a helium-neon laser comes from certain energy level transitions of electrons in the gas, that is quantum events. Look how well they synch up and produce a coherent beam of light.
    Further, if you were using 241Am decay as a randomness source. A possible way to "fix" the result is to add enough extra Am around it, about 60Kg, such that it goes critical. See how random that is[noparse]:)[/noparse]
    edited 2010-07-04 13:21
    Electrical noise might be OK for some purposes, but you won't find anyone using it for, say, cryptographic research. It was used by the "PEAR people" at Princeton for their much-criticised experiments into "quantum consciousness". I actually asked their leader once why they didn't use quantum RNGs, and he was rather dismissive of the idea, probably because their results depended on a poor-quality RNG.
    With a laser, you are actually looking at a macro effect, not something based on the properties of individual photons.
    See how idQuantique handles the processing of data from the single-photon detector they use in their Quantis unit.
    Leon Heller
    edited 2010-07-04 13:47
    Leon: "Electrical noise might be OK...won't find anyone using it for...cryptographic research."
    True enough and quite reasonable given the desire for immunity from external influence I discussed. I still maintain that you quantum entropy detector has to be built with external influence in mind. Not at the quantum end so much but on the path up from there.
    Nothing to say about the "PEAR" people. They just seem to be loony toons to me[noparse]:)[/noparse]
    I absolutely disagree that a Laser is a macroscopic effect. That is it is NOT like Newtonian mechanics and utterly depends on quantum mechanical properties of the atoms used. Without introducing the idea of "quanta" of energy the laser cannot be explained. With that comes all the associated quantum mechanics.
    Admittedly you need a lot of HeNe in a tube to make a laser, for example, so it looks macroscopic.
    I refer you to this history of the laser: www.aps.org/publications/apsnews/200508/history.cfm
    In which we read "If one has a large collection of atoms containing a great deal of excess energy, they will be ready to emit a photon randomly. However, if a stray photon of the correct wavelength passes by (or, in the case of a laser, is fired at an atom already in an excited state), its presence will stimulate the atoms to release their photons early–and those photons will travel in the same direction with the identical frequency and phase as the original stray photon."
    What I'm kind of getting at is that with random number generators based on quantum decay one has a similar situation to that described above. A large collection of atoms...excess energy... ready to emit...randomly...However....
    edited 2010-07-04 14:02
    With a laser you aren't seeing the events of single photons, as you are with a quantum RNG. How would would you go about using one as an RNG? With radio-active decay, you can see the output from single atoms, if you wish.
    Leon Heller
    edited 2010-07-04 15:09
    Yes, yes indeed that's true. However what I'm getting at is the fact that the radioactive decay can be tampered with. As I said if your source is 241Am and I happen to a surround it with enough extra 241Am to get a critical mass. All of a sudden your output is not what you expect!
    This analogous to a the electrons of a single atom decaying from a high energy level to a lower one. It will happen at random. But surround the thing by enough similarly energized atoms and you get stimulated emission and coherence.
    This is a great debate, but it reminds me of a time two decades ago when I was working on a hand held military wireless communications project. When we came to the requirment for randomness and entropy for the crypto we had a problem. It pretty much halted development for a month as all the team members got to grips with "what is randomness", what does "random" mean and where do we get some of this? Didn't help that we had GCHQ looking over our shoulders to make sure we got the right kind[noparse]:)[/noparse]. The discussion got similarly philosophical then.
    So we should give this a little rest whilst I get Zog moving[noparse]:)[/noparse]
    edited 2010-07-04 15:23
    I worked at Racal on Yeoman, their bid for the Bowman radio contract. All the radios apart from the personal radio incorporated the GCHQ Pritchel crypto. We didn't have any details of the inner workings of it, of course. I conducted verification tests for the MOD on radios equipped with it.
    A pritchel is a pointy thing used by blacksmith's to make holes in things like horse shoes, BTW.
    Leon Heller
    Post Edited (Leon) : 7/4/2010 3:57:50 PM GMT
    edited 2010-07-04 21:22
    Leon said...
    I think that what they needed for their purposes was an event of sufficient
    randomness that could be shifted by some sort of unknown method(force?).
    Crypto quality was not needed. If the stream of data from the PEAR RNGs shifted
    in a significant way that was correlated to major events then that's all that was necessary.
    I think electrical noise like that produced by a noisy diode was sufficient.
    If a poor-quality quantum RNG shifts at the right time then that is good enough and provides the
    same level of proof as a perfect quantum RNG would.
    edited 2010-07-04 23:02
    Schrodinger's cat is dead.
    Schrodinger's cat is not dead.
    edited 2010-07-04 23:25
    HollyMinkowski said...
    Leon said...
    Given the vast number of events that take place each day, a poor quality RNG is more likely to correlate with one of them than a good quality one, I would have thought. The PEAR people have even claimed that they detected anomalies *before* something happened! No one has been able to replicate their results, of course. They couldn't even replicate them themselves in a different lab.
    Leon Heller
