A nice, THIN, LCD w/cable that connects to the Propeller?
As most of you know, I have recently designed a Digital Time Clock for small businesses. I have in in action now, (at a business) and it has been working nicely. The good thing is that there could be potential market for this device, the bad thing is that one of the parts, the LCD, is of unique origin and the last remaining supplies are almost depleted. Does someone know of a small, thin, (and yes it has to be no more then 4 millimeters thick) LCD that works well with the Propeller? It can be graphical or segmented, doesn't matter. It has to connect with a ribbon or other type of cable. Does anyone know of one like this?
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Micro
I have used them in the past and was able to write a driver in PSAM. The ones I have are pretty thin. Most, if not all do not come with a cable, but most can be easily soldered to.
Jim Fouch
FOUCH SOFTWARE
Hantronix LCD Graphic Display Module: Gray Reflective Chip on Glass
www.mouser.com/ProductDetail/Hantronix/HDG12864F-1-S00F/?qs=sGAEpiMZZMvkC18yXH9iIuqOXjRftzY9HZEwQNfdvdA%3d
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
There is an asm driver in the obex that will drive it. You need caps for the negative voltage. The display is driver compatible with the samsung s6b0724.
Also these two may be of interest -
www.mouser.com/ProductDetail/Newhaven-Display/NHD-C12832A1Z-FSW-FBW-3V3/?qs=sGAEpiMZZMvkC18yXH9iIjqe6IqxYXYlWEPha%2fvwHCQ%3d
www.mouser.com/ProductDetail/Displaytech/S64128K-FC-BW-3/?qs=sGAEpiMZZMvkC18yXH9iIphA15G1WjP185cbuPG%2fGsw%3d two or three sizes in this form factor
Both of these should be driveable with the obex driver. The newhaven is one I haven't used, it has an spi interface, if you are pin limited.
A couple of things to remember when choosing an lcd -
FSTN is the dark black on white typically
Color LCD's look nice, but a good monochrome FSTN can be read in direct sunlight.
This looks like it fits the mechanical specs! The only problem is there is no cable. Oh, well. I should order one for prototyping.
-Larry G.
