Microchip SRAM
Hello all,
I am trying to get a microchip sram 23k256 ic working. I used the winbond flash and microchip sram driver from the object excange.
This is my code: (whitch doesnt work, I only read a 9, 0 or 255 instead of the value it should be)
I think that I am doing something wrong with the variables (@ or not @?).
CON
_clkmode = xtal1 + pll8x
_xinfreq = 10_000_000
'Audio / video output
L_Audio = 5 'Sound (L) output
R_Audio = 6 'Sound (R) output
COMPOSITE_VIDEO = 12 'Video output
'Controllers
PS2_toetsenbord_dat = 16 'Toetsenbord data i/o
PS2_toetsenbord_clk = 17 'Toetsenbord clk output
PS2_muis_dat = 3 'Muis data i/o
PS2_muis_clk = 4 'Muis clk output
gc_controller_1 = 7 'Gamecube controller 1 data i/o
gc_controller_2 = 8 'Gamecube controller 2 data i/o
'Intern RAM geheugen
SRAM_CLK = 1 'RAM clk output
SRAM_DIO_DI = 2 'RAM data output
SRAM_DO = 9 'RAM data input
SRAM_CS1 = 10 'RAM chipselect 1
SRAM_CS2 = -1'11 'RAM chipselect 2 (niet gebruikt, zie EXP_P8)
'SD kaart aansluiting
SD_CARD = 24 'SD Kaart basepin
spiDO = 24 'SD Kaart data input
spiClk = 25 'SD Kaart clk output
spiDI = 26 'SD Kaart data output
spiCS = 27 'SD Kaart chip select
'Interne eeprom chip voor bootloader
eeprom_clk = 28 'EEPROM clk output
eeprom_dat = 29 'EEPROM data i/o
'Interne communicatie met PIC chip
serial_tx = 30 'PIC tx output
serial_rx = 31 'PIC rx input
'Uitbreidingspoort (universeel)
EXP_P0 = 18
EXP_P1 = 19
EXP_P2 = 20
EXP_P3 = 21
EXP_P4 = 22
EXP_P5 = 23
EXP_P6 = 5
EXP_P7 = 0 'Nu nog een LED!
EXP_P8 = 11'Was voor SRAM CS!
VAR
byte sram_data, sram_adres, sram_data_check
OBJ
text : "TV_Text_Half_Height"
ram : "ram_flash"
PUB start | i
text.start(12,1,0,40,15)
repeat
enter
text.ink(5&7)
text.str(string("RAM TEST"))
enter
text.ink(6&7)
text.str(string("v1.4"))
'text.inkblock(5,2,30,11,1)
ram.start(-1, SRAM_CLK, SRAM_DIO_DI, SRAM_DO, SRAM_CS1, SRAM_CS2)
text.ink(2&7)
'TEST RAM
enter
text.str(string("Writing SRAM... (adr 0 t/m 20)"))
enter
sram_data:= 0
sram_adres:= 0
repeat 20
text.str(string("."))
ram.writeSRAM(@sram_adres, @sram_data, -1)
sram_data:= sram_data + 2
sram_adres:= sram_adres + 1
waitcnt(cnt+1_000_000)
enter
text.str(string("Reading SRAM... (adr 0 t/m 20)"))
enter
sram_data:= 9
sram_data_check:= 0
sram_adres:= 0
repeat 20
'if sram_adres == 100
' quit
ram.readSRAM(@sram_adres, @sram_data, -1)
sram_data_check:= sram_data_check + 2
if not (sram_data == sram_data_check)
enter
text.str(string("Error occured on adress "))
text.dec(sram_adres)
enter
text.str(string("Read: "))
text.dec(sram_data)
text.str(string(", should be: "))
text.dec(sram_data_check)
waitcnt(cnt+40_000_000)
else
text.str(string("Actie succesvol!"))
enter
waitcnt(cnt+160_000_000)
PUB cls
text.out($00)
text.out($01)
PUB enter
text.str(string($0D))
ram.writeSRAM(@sram_adres,·@sram_data,·-1)
the first parameter is the address in the SRAM and not the address of the sram_adres variable. You really want to give this function the 0 for addressing byte 0 in the SRAM. Whenever you really want to pass the value of a variable, there is no @ involved.
@sram_data seems to be ok.
-1 ? Is that the number of bytes you want to write to the SRAM? Gonna have a look into your archieve to be a better help ....
So, you have to say:
sram_data := ram.readSRAM( sram_adres, 0 , -1)
ram.readSRAM( sram_adres, @sram_data, 1 )
The write works similar
ram.writeSRAM( sram_adres, sram_data, -1)
ram.writeSRAM( sram_adres, @sram_data, 1 )
The functions have been designed like that to support direct value passing or passing bigger amount of data by buffers.
