Inverter with Auto Switch to AC Power
I'm working on a small solar project for my house to run a few items.
Solar panel, charge controller, battery and inverter are installed and work well.....until the battery drops below min. charge and the whole system shuts down [noparse]:([/noparse]
What I'm trying to find is an inverter with a built in switch back to utility provided AC when the battery drops below min. charge level.
I've found several units that work the opposite, if utility AC fails, inverter switches to battery.
Any thoughts or suggestions are much appreciated.
Simple but effective!?
The only thing I see with this is.... it'd be nice if there were a time delay maybe, so the batteries would charge a little before coming back on-line in the morning.
"puff"...... Smile, there went another one.
Post Edited (Spiral_72) : 7/2/2010 3:12:01 PM GMT
Maybe there won't be an inrush though..... the switch time would / should be very small.... 10ms or less I would guess for a big relay.
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
I had a Idea .. some inverters have a set of LEDs taht one could use as a batt Low Siganal to switch a relay
EG one of my UPSes has a BAT LOW led . thats green then red .. With some clever hacking I could use it with a Opto Iso to drive a relay .........
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
I've started to rough out the circuit for this, but I'm stuck on the ground leg of the AC side of the project.
The relay will switch the hot wire from the inverter to the utility AC. Can I split the common and have it connect to both the inverter and the utility AC?
I'd agree 100%. Pretty simple solution eh?
need additional details on the control voltage for the relay. where to get it and where to connect it.
I love these, but it may not be big enough for you:
http://www.automationdirect.com/adc/Shopping/Catalog/Relays_-z-_Timers/Fuji_Timer_Relays_1-z-16_DIN_(MS_Series)/MS4SA-AP-ADC
This is just the relay. I've never used this one at 15A, but the spec says it'll do it:
http://www.automationdirect.com/adc/Shopping/Catalog/Relays_-z-_Timers/15A_Electro-Mechanical_Cube_Relays/782-2C-120A
You'll have to look around but the timer relay would be perfect (I think). Surely Fuji... Koyo.... (Square-D MIGHT make one) would have a timer relay rated for 15A or so.
Post Edited (Spiral_72) : 7/2/2010 7:36:57 PM GMT
Anyway, hope this makes sense and gives you some ideas.
