SMD Oven soldering without stencils
william chan
Since stencils are costly, why can they put solder paste into a syringe and needle so we can squeeze out tiny amounts onto each smd pad?
Wouldn't this way be easier and cheaper?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Jim
Why do you say it is expensive? You can get plastic for 35+, small metal for 100, and fairly large stretched stencils for 175+
Once you have done the stretched stencil, you will fall in love with it.
use it right away without any solder paste? (maybe just add a bit of flux before putting into oven )
Wouldn't it be much faster and cheaper this way?
www.fd.com.my
www.mercedes.com.my
Leon Heller
Amateur radio callsign: G1HSM
In regards to the syringe method, it does work in high volume applications using dispensing equipment, but when using a small needle, the pressure used to force the paste through the needle opening does produce friction which leads to heat and can alter the performance of the flux in the paste. When doing it by hand, the application does get exhausting really quick and the accuracy of application may limit you to passive components or maybe some larger QFPs or SOICs unless you don't mind doing solderwick touch-up.
In regards to using HASL to solder, the thickness of HASL is not sufficient for this method. HASL is still a common method of plating and is still performed by almost all FAB houses, but with the lead-free hogwash*, it is easier to use an ENIG or Gold Flash plating process as opposed to a SAC305 HASL (I do build boards at work that use SAC305 HASL by the way, so don't think it doesn't get used).
A common rework method for QFNs and BGAs is to tin the pads on the board with a good amount of solder, apply a tacky rework flux, place the part onto the pads, then reflow using IR, hot air, or a reflow oven.
*start.rant
yes, I truly believe the lead free initiative is hogwash because of it's poorly handled implementation and, overall, is more damaging to the environment than tin/lead when you factor in things like the extra energy consumed by reflow ovens for the higher temps, increase chemical usages when manufacturing lead free solders, increased usage of dry-packs due to higher MSL parts, etc. It was originally intended to battle heavy lead products like TVs, but applying it across the board for everything has really caused more damage then good. I like the US Army's stance on lead free myself: don't use it
stop.rant
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Post Edited (WBA Consulting) : 7/2/2010 5:13:28 PM GMT
