Cheap, easy and powerful video system. Does such a thing exist?
It seems like one of the biggest things plaguing robotics/ drones, is the use of a good video system. The current system i have cost me $70 and only gets me a range of 100 feet. Of course there are a few obstructions, but that is just no good for a long range robot. I have rigged up a robot control method using a sound impact sensor and a cell phone to provide control of the·micro controller/ robot·from anywhere in the world, but this will do me no good if the wireless camera can only go a hundred feet of less. I have heard about usb wireless cameras, but finding a good one is nearly impossible. I guess my big question is, What kind of video system do you guys use? And is it on the inexpensive side?· THANKS FOR YOUR TIME
Propeller + Picaxe = Romeo & Juliet
John Abshier
2.4Ghz RC transmitters have a range of up to about 2miles. I have no idea what the data rate is, but they sell 2.4Ghz transmitter modules compatible with JR radios. It plugs in piggy-back with a controller (eg. JR-9303) It's a long shot, but it "Might" work. If so you'd have a range of 2 miles for 4hrs off a 1500mA pack. The data rate is mighty fast for RC stuff, but video??? I dunno. If I remember right there are only about ten pins off the device and two of those are power...
Good luck
"puff"...... Smile, there went another one.
We also did that with a G2 and a flying wing plane.
We also put schematics and firmware up for download [noparse];)[/noparse] Also videos.
http://robots-everywhere.com/re_wiki/index.php?title=Main_Page
(can the firmware go on the obex or is it too specific?)
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
Post Edited (M. K. Borri) : 7/4/2010 2:36:50 AM GMT
BTW, do you happen to have the code for the computer side of your robots readily available?
90 * 2 = Pi
The cost range depends on features, including lens quality, fixed or zoom lens, fixed mounting or built in pan/zoom, and other options. These things can be a slick solution, ***-u-me-ing you have a way to get enough bandwidth to/from your robot. Some even have serial ports built in to allow using the IP stream to also communicate with the microprocessor.
John R.
Click here to see my Nomad Build Log
