Strange behvior with 4x20 LCD **solved**
I am using the Serial LCD driver from obex, which in turn uses simple serial.
I have discovered some strange behavior. Every other cycle through my screen update process the second line of the lcd is overwritten by the forth line, hence the updated value being displayed alternates between what should be on the second line and the fourth line.
The LCD driver is using 19200 baud.
Here is the routine that updates the screen:
Is this something that is known about ? or am I maybe just feeding the data too fast? an Issue with simple serial? I have dumped the values of the variables being used to pst and they are correct.
Post Edited (Greg LaPolla) : 6/30/2010 9:30:40 PM GMT
PRI SpargeUpdate (_mash,_hlt,_time) lcd.home lcd.gotoxy(7, 1) lcd.str(num.decf(_mash, 3)) lcd.gotoxy(7, 2) lcd.str(num.decf(_hlt, 3)) lcd.gotoxy(7, 3) lcd.str(num.decf(_time,3)) waitcnt(clkfreq / 5 + cnt)
I'm just 7*1027 atoms floating through time and space in close formation. -KF4IXM
