Send ROM (or RAM) from Prop to PC as a binary file using YMODEM and Hypertermin — Parallax Forums
RaymanRayman Posts: 16,073
edited 2010-06-30 14:18 in Propeller 1
I wanted to capture the ROM font as a binary file...
So, I made a couple changes to my YMODEM example code and got it.
Anyway, thought I'd share...· Also, this is a very simple example.
It also displays on TV or VGA, but that really isn't necessary.
All you need is a Prop with serial connection, such as PropPlug, to a PC running Hyperterminal (or similar program).
Here's an image I made with Visual C++ using this ROM font:
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Post Edited (Rayman) : 6/30/2010 2:11:44 PM GMT
