IR sensor malfunction
This is just your Basic Stamp, BoeBot bs2 code. Having trouble with the IR sensor. When I go to the debug terminal it doesn't pick up my hand or any other object in front of it. IR just simply doesn't work. Tried redoing the whole circuitry to see if that was the problem(did it with the same jumper cables etc) but still doesn't work. I haven't used it for a year or so and wanted to use it again but doesn't work since I've been trying to get it working again.
Any suggestions?
Any suggestions?
2. post your schematic
3. post a picture of your wiring
create bitmap data tool: 1uffakind.com/robots/povBitMapBuilder.php
resistor ladder tool: 1uffakind.com/robots/resistorLadder.php
convert images to ascii art: 1uffakind.com/apptoys/convtoascii/
You say your program is perfect and your wiring is perfect but it doesn't work, so ... asking you to post the program, the schematic and the wiring seems reasonable.
If the schematic is "by the book from Parallax", then which book/page? A photo of your setup may help a viewer to see where you miswired somewhere, or some other obvious error that may be quickly spotted by someone with fresh eyes.
Take the essential components and test them separately to see if they work on their own (i.e., hook the IR led up to 5v through a resistor and see if it illuminates when viewed through a digital camera; hook up the output of the detector to the cathode of a regular LED, and see if the LED flashes when you aim a regular TV remote at the detector; etc). But that's just shots in the dark w/o more info. Help the forum members help you.
Post Edited (Zoot) : 6/29/2010 8:40:04 PM GMT
