combining variables — Parallax Forums
combining variables
ThricThric Posts: 109
edited 2010-06-27 14:27 in Propeller 1
I'm trying to create a program that finds a single characther in a txt file that·is located on a SD card and then stores that value into an array. However when a certain charcheter is reached (like a comma) then I need to combine all my previous values so that I end up with a number. Heres an example:
buf[noparse][[/noparse]1]:=5, buf[noparse][[/noparse]2]:=8, and buf[noparse][[/noparse]3]:=","
then I need to some how store buf[noparse][[/noparse]1] and buf[noparse][[/noparse]2] into a single variable to equal 58.
·Sorry if its a little confusing, its hard for me to explain something I don't know how to do confused.gif .
  • MacGeek117MacGeek117 Posts: 747
    edited 2010-06-26 14:39
    Hey, Thric! Welcome to the Forums!
    All you Prop pros out there correct me if I'm wrong on this, but I believe you can do something like this:
    x := (buf * 10) + buf
    MG117
    BS2: $49
    SX48 Protoboard: $10
    Propeller Protoboard: Priceless
    www.apple.com
    www.parallax.com
    www.goldmine-elec.com
    www.expresspcb.com
    www.jameco.com
  • ThricThric Posts: 109
    edited 2010-06-27 03:11
    Thanks for the reply,
    · will this work with the following example?
    buf[noparse][[/noparse]1]:=2·· buf[noparse][[/noparse]2]:=3 ·buf[noparse][[/noparse]3]:=7 ·buf[noparse][[/noparse]4]:="."· buf[noparse][[/noparse]5]:=9 ·buf[noparse][[/noparse]6]:=","
    So the outcome will have to be 237.9
    Post Edited (Thric) : 6/27/2010 3:17:21 AM GMT
  • John AbshierJohn Abshier Posts: 1,116
    edited 2010-06-27 04:29
    If you want to print the character 2 buf := 2 + 48 because the ascii code for 2 is 50 (decimal). Take a look at Simple_Numbers.spin in the library (where the propeller.exe file is located)
    John Abshier
    edited 2010-06-27 09:25
    one thing to clear up is:
    do you want the numbersmfor calculations inside the prop or are you just displaying them?
    In the commandset of the SPIN-interpreter you can only calculate with INTEGERs.
    For floating point you would have to use floatingpoint math-object
    If you want the numbers only to DISPLAY with really really NO calculations you can do this
    buf[noparse][[/noparse] 1 ]:=2 buf[noparse][[/noparse] 2 ]:=3 buf[noparse][[/noparse] 3 ]:=7 buf[noparse][[/noparse] 4 ]:="." buf[noparse][[/noparse] 5 ]:=9 buf[noparse][[/noparse] 6 ]:=","
    defining a second array of bytes
    CON
      _xinfreq = 5_000_000       'chrystal-frequency
      _clkmode = xtal1 + pll16x  'clockmode
    OBJ
      Debug : "FullDuplexSerial"
    VAR
      long Index
      byte buf[noparse][[/noparse] 7 ]
      byte MyCharArray[noparse][[/noparse] 7 ]
    PUB Main
      Debug.Start(31,30,0,115200) 'start cog with serial driver
      Debug.Str(string("Debug-output started",13))
      buf[noparse][[/noparse] 1 ] := "2"
      buf[noparse][[/noparse] 2 ] := "3"
      buf[noparse][[/noparse] 3 ] := "7"
      buf[noparse][[/noparse] 4 ] := "."
      buf[noparse][[/noparse] 5 ] := "9"
      buf[noparse][[/noparse] 6 ] := ","
      repeat index from 1 to 5
        MyCharArray[noparse][[/noparse] Index ] := buf[noparse][[/noparse] Index ]
      MyCharArray[noparse][[/noparse] 6 ] := 0
      Debug.Str(string("right before output",13))
      Debug.Str(@MyCharArray[noparse][[/noparse] 1 ])
      Debug.Tx(13)
      Debug.Str(string("Output done",13))
    remember as soon as you want to do any kind of calculations you have to convert the characters into a real integer
    how this works depends on the format how your numbers are stored on the SD-card
    the above example will work if the numbers are stored as ASCII-codes characters
    so next step for you is to post an answer with more information of how the values are stored and what you want to to with the values
    best regards
    Stefan
    edited 2010-06-27 14:04
    Thanks for all the replys,
    The informations is stored on the sd card in a txt file as ASCII. What I want to do is take each character into a a buffer till a comma is found then combine those numbers and do some further calculations with them. the object I'm using for my sd card is the Fat 16 routines by john Twomey (http://obex.parallax.com/objects/402/) if this helps at all.
  • JonnyMacJonnyMac Posts: 9,819
    What you need is a method to convert your string characters to a value -- like this:
    pub str2dec(pntr) | val, c
      val := 0                                                      ' clear workspace
      repeat
        c := byte[noparse][[/noparse]pntr++]                                           ' get character, point to next
        if (c => "0") and (c =< "9")                                ' digit?
          val := (val * 10) + (c - "0")                             ' yes, add to value
        else
          quit                                                      ' no, we're done
      return val
    To use it you will pass a pointer to the first character of the string you want to convert, for example:
    value := str2dec(@buf[noparse][[/noparse] 1 ])
    Jon McPhalen
    Hollywood, CA
