Access Violation
Hello,
I just installed the newest version of BASIC Stamp Editor v2.5 off the website, and whenever I try to load the program after a successful installation, it fails to open. I get the "BASIC Stamp Editor has stopped working" error, and occasionally I get an "access violation at address 0056269D in module stampw.exe" error. Nothing I've tried seems to fix this problem.
I've run it in every compatibility mode I can, with and without administrator access.
I've uninstalled my anti-virus software.
I've re-installed twice & restarted my computer a few times.
Can someone please help me solve this issue.
Thanks in advance,
Joel
Thanks in advance,
Joel
Tell us about the computer and operating system.
Tom Sisk
http://www.siskconsult.com
- Stephen
Do by any chance you have another serial device connected to your computer? Say a Palm or some other sort of PDA?
DJ
No other serial device attached to the computer
Will try uninstalling, restarting & re-installing again. I think I did this last night, but am not positive.
- Stephen
I'm using the HomeWork board, with the built-in stamp, connected directly to my USB-to-Serial adapter.
Also, this board works on my other computer just fine. So, I'm pretty sure it's a local computer software issue...
- Stephen
So, it looks like a re-install of windows it is. Kind of unfortunate, but I guess that's how it goes...
-Joel
When I changed my (older) ASUS EEEpc from Linux to XP, it was a pretty tight squeeze, but it works like a charm and I can do all the normal Stamp stuff and use Open Office for non-Stamp work. The system is very low on resources most of the time.
Intuitively, I'd say Win 7 would be a somewhat tighter squeeze unless you've got more disk space.
Tom Sisk
Did you formate the drive to clear XP from it before you loaded Win 7 ???. This access error sounds like XP is still running in the back round. I'm not sure if " C:/formate/ U" works on a solid state drive?
Remember _google_ is your friend.
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
