HB-25 Motor controller not functioning correctly — Parallax Forums
navila17navila17 Posts: 12
edited 2010-06-24 15:27 in Propeller 1
Hello,
I have been using a HB-25 motor controller with my propeller demo board. Once I figured out how t communicate with it correctly, it was working ok. But now I go to try it out this morning and it is acting funny. So I decide to just send specific pulses to it and read what it does on a multi-meter. For some reason it will only put out 0 volts, or 100% negative or positive, no matter what pulse I send to it. For example, if I send a 1.250ms pulse, this should put out half power, but it puts out the full 100% voltage. It seems to be unrelated to voltage as I am using a variable power supply and tried with a few voltages.
I have tried power cycling and redoing all the wires/connections a few times already and it doesn't help.
Is it pretty much just broken? Or does anyone think there is a way to fix it?
Nick
    edited 2010-06-24 14:21
    Try powering up the microcontroller first, then the HB-25. Did this solve the problem?
    These little guys are finicky in this way. See page 5 of the product docs.
    And if it's actually broken, no worries - we'll replace it.
    Parallax Inc.
    Follow me at http://twitter.com/ParallaxKen for some insider news.
  • navila17navila17 Posts: 12
    edited 2010-06-24 14:36
    Thanks for the reply. Yes I do always try to start the micro controller first, doesn't seem to help. It was working yesterday, then this morning I didn't change anything at all but now I am getting these wrong voltages. So I guess it is broken. How do I go about getting it replaced? I've never had to return anything from Parallax yet, I guess that's pretty good on your part. If it is better, you can just email me back at nickavila1@gmail.com
    Thanks a lot,
    Nick
  • JonnyMacJonnyMac Posts: 9,620
    Keep in mind that the output is PWM'd, so checking with a multimeter is not going to be helpful. For a real test you'll need to connect a 'scope to compare the duty-cycle output with the command that you're sending.
    Also, the HB-25 has its own initialization period; are you following the start-up protocol to monitor the command line (for its ready state) before you attempt to send pulses to the device?
    If you do have a bad device you'll need to call Parallax.
    Jon McPhalen
    Hollywood, CA
