delay problem with multilpe serial port using pcFullDuplexSerial4FC solved — Parallax Forums
Julian800Julian800 Posts: 31
edited 2010-06-29 23:43 in Propeller 1
I am planning a project send ASIC· data stream· to multiple device ‘s RS422/RS485 port.· I know there is a multilpe serial port drive from Tim Moore in the OBEX.··· Can I use that one with some chip to do multiple· RS422/RS485· ?·
I know nothing about serial communications, etc. so I need to take this on one baby step at a time. Any suggestions will be greatly appreciated.
Post Edited (pussycat) : 6/29/2010 11:46:24 PM GMT
  • JonnyMacJonnyMac Posts: 9,819
    edited 2010-06-23 01:08
    You should contact that programmer for specific guidance. I've used two instances of FullDuplexSerial in a project; one for RS-485 comms and another for Propeller-to-PC comms. If you're not short of cogs this may be a cleaner solution.
    Jon McPhalen
    Hollywood, CA
  • T ChapT Chap Posts: 4,260
    edited 2010-06-23 01:56
    I use one port of the 4port with RS485, no reason you couldn't do up to 4 RS485 ports with it. The only trick is you have to have control the enable pins as needed, and they require a short delay time to change states before sending the data over RS485.
  • Julian800Julian800 Posts: 31
    edited 2010-06-29 01:21
    thanks for your help Jon and Todd. I get code running. But there is 200 ns delay for send each of byte in pcFullDuplexSerial4FC. that don't happen in FullDuplexSerial. Anyone know the delay of pcFullDuplexSerial4FC?·
    what i need to do is only sending data on 2 serial under 2ms by using
    I also try to find the delay by my self.·I delete all sending code and serial 2 and serial 3. But there is still 500 microsecond delay between send of serial 1 and serial 2, also delay 100 microsecond delay of each byte.
    entry
    'rxcode· if_never······· mov···· rxcode,#receive······ 'statically set these variables
    txcode· if_never······· mov···· txcode,#transmit
    'rxcode1 if_never······· mov···· rxcode1,#receive1
    txcode1 if_never······· mov···· txcode1,#transmit1
    'rxcode2 if_never······· mov···· rxcode2,#receive2
    'txcode2 if_never······· mov···· txcode2,#transmit2
    'rxcode3 if_never······· mov···· rxcode3,#receive3
    'txcode3 if_never······· mov···· txcode3,#transmit3
    'port 1
    ······················· test··· rxtx_mode1,#OCTX wz·· 'init tx pin according to mode
    ······················· test··· rxtx_mode1,#INVERTTX wc
    ······· if_z_ne_c······ or····· outa,txmask1
    ······· if_z··········· or····· dira,txmask1
    ······· if_z_eq_c······ or····· txout1,domuxnc······· 'patch muxc to muxnc
    ······· if_nz·········· movd··· txout1,#dira········· 'change destination from outa to dira
    ······················· test··· rxtx_mode1,#INVERTRX wz 'wait for start bit on rx pin
    ······ ' if_nz·········· xor···· start1,doifc2ifnc···· 'if_c jmp to if_nc
    ······················· or····· ctsmask1,#0···· wz
    ······· if_nz·········· test··· rxtx_mode1,#INVERTCTS wc
    ······· if_nz_and_nc··· or····· ctsi1,doif_z_or_nc··· 'if_nc jmp
    ······· if_nz_and_c···· or····· ctsi1,doif_z_or_c···· 'if_c jmp
    ······· if_z··········· mov···· txcts1,transmit1····· 'copy the jmpret over the cts test
    ······· if_z··········· movs··· ctsi1,#txcts1········ 'patch the jmps to transmit to txcts0·
    ······· if_z··········· add···· txcode1,#1··········· 'change co-routine entry to skip first jmpret
    ····················································· 'patch rx routine depending on whether rts is used
    ····················································· 'and if it is inverted
    ······················· or····· rtsmask1,#0···· wz
    ······· if_nz·········· test··· rxtx_mode1,#INVERTRTS wc
    ····· '· if_nz_and_nc··· or····· rts1,domuxnc········· 'patch muxc to muxnc
    ··· '··· if_z··········· mov···· norts1,rec1i········· 'patch to a jmp #receive1
    ····· '· if_z··········· movs··· start1,#receive1····· 'skip all rts processing·················
    ······················· or····· txmask1,#0····· wz
    '······· if_z··········· mov···· txcode1,rxcode2······ 'use variable in case it has been changed
    ······················· or····· rxmask1,#0····· wz
    '······· if_z··········· mov···· rxcode1,txcode1······ 'use variable in case it has been changed
    'port 0
    ······················· test··· rxtx_mode,#OCTX wz··· 'init tx pin according to mode
    ······················· test··· rxtx_mode,#INVERTTX wc
    ····················································· 'patch tx routine depending on invert and oc
    ····················································· 'if invert change muxc to muxnc
    ····················································· 'if oc change out1 to dira
    ······· if_z_eq_c······ or····· txout0,domuxnc······· 'patch muxc to muxnc
    ······· if_nz·········· movd··· txout0,#dira········· 'change destination from outa to dira
    ····················································· 'patch rx wait for start bit depending on invert
    ······················· test··· rxtx_mode,#INVERTRX wz· 'wait for start bit on rx pin
    ······ ' if_nz·········· xor···· start0,doifc2ifnc···· 'if_c jmp to if_nc
    ····················································· 'patch tx routine depending on whether cts is used
    ······················· or····· ctsmask,#0···· wz···· 'cts pin? z not set if in use
    ······· if_nz·········· test··· rxtx_mode,#INVERTCTS wc 'c set if inverted
    ······· if_nz_and_nc··· or····· ctsi0,doif_z_or_nc··· 'if_nc jmp
    ······· if_nz_and_c···· or····· ctsi0,doif_z_or_c···· 'if_c jmp
    ······· if_z··········· mov···· txcts0,transmit······ 'copy the jmpret over the cts test
    ······· if_z··········· movs··· ctsi0,#txcts0········ 'patch the jmps to transmit to txcts0·
    ······· if_z··········· add···· txcode,#1············ 'change co-routine entry to skip first jmpret
    ······················· or····· rtsmask,#0···· wz···· 'rts pin, z not set if in use
    ······· if_nz·········· test··· rxtx_mode,#INVERTRTS wc
    ··· '··· if_nz_and_nc··· or····· rts0,domuxnc········· 'patch muxc to muxnc
    ···· '·· if_z··········· mov···· norts0,rec0i········· 'patch to a jmp #receive
    ···· '·· if_z··········· movs··· start0,#receive······ 'skip all rts processing if not used
    ····················································· 'patch all of tx routine out if not used·················
    ······················· or····· txmask,#0······ wz
    '······· if_z··········· mov···· txcode,rxcode1······· 'use variable in case it has been changed
    ····················································· 'patch all of rx routine out if not used·················
    ······················· or····· rxmask,#0······ wz
    '······· if_z··········· mov···· rxcode,txcode········ 'use variable in case it has been changed
    ' Transmit
    transmit··············· jmpret· txcode,txcode1······· 'run a chunk of receive code, then return
    ····················································· 'patched to a jmp if pin not used·······················
    txcts0················· test··· ctsmask,ina···· wc··· 'if flow-controlled dont send
    ······················· rdlong· t1,tx_head_ptr······· '{7-22} - head[noparse][[/noparse]0]
    ······················· cmp···· t1,tx_tail····· wz··· 'tail[noparse][[/noparse]0]
    ctsi0·· if_z··········· jmp···· #transmit············ 'may be patched to if_z_or_c or if_z_or_nc
    ······················· rdbyte· txdata,txbuff_tail_ptr '{8}
    ······················· add···· tx_tail,#1
    ······················· and···· tx_tail,#$0F··· wz
    ······················· wrlong· tx_tail,tx_tail_ptr··· '{8}·
    ······· if_z··········· mov···· txbuff_tail_ptr,txbuff_ptr 'reset tail_ptr if we wrapped
    ······· if_nz·········· add···· txbuff_tail_ptr,#1··· 'otherwise add 1
    ······················ ' jmpret· txcode,rxcode1
    ······················· shl···· txdata,#2
    ······················· or····· txdata,txbitor······· 'ready byte to transmit
    ······················· mov···· txbits,#11
    ······················· mov···· txcnt,cnt
    txbit·················· shr···· txdata,#1······ wc
    txout0················· muxc··· outa,txmask·········· 'maybe patched to muxnc dira,txmask
    ······················· add···· txcnt,bit_ticks······ 'ready next cnt
    :wait················· ' jmpret· txcode,rxcode1······· 'run a chunk of receive code, then return
    ······················· mov···· t1,txcnt············· 'check if bit transmit period done
    ······················· sub···· t1,cnt
    ······················· cmps··· t1,#0·········· wc
    ······· if_nc·········· jmp···· #:wait
    ······················· djnz··· txbits,#txbit········ 'another bit to transmit?
    txjmp0················· jmp···· ctsi0················ 'byte done, transmit next byte
    ························ jmp···· #transmit
    ' Transmit1
    transmit1·············· jmpret· txcode1,txcode······ 'run a chunk of receive code, then return
    txcts1················· test··· ctsmask1,ina··· wc··· 'if flow-controlled dont send
    ······················· rdlong· t1,tx_head_ptr1
    ······················· cmp···· t1,tx_tail1···· wz
    ctsi1·· if_z··········· jmp···· #transmit1··········· 'may be patched to if_z_or_c or if_z_or_nc
    ······················· rdbyte· txdata1,txbuff_tail_ptr1
    ······················· add···· tx_tail1,#1
    ······················· and···· tx_tail1,#$0F·· wz
    ······················· wrlong· tx_tail1,tx_tail_ptr1
    ······· if_z··········· mov···· txbuff_tail_ptr1,txbuff_ptr1 'reset tail_ptr if we wrapped
    ······· if_nz·········· add···· txbuff_tail_ptr1,#1·· 'otherwise add 1
    ····················· '· jmpret· txcode1,rxcode2······ 'run a chunk of receive code, then return
    ······················· shl···· txdata1,#2
    ······················· or····· txdata1,txbitor······ 'ready byte to transmit
    ······················· mov···· txbits1,#11
    ······················· mov···· txcnt1,cnt
    txbit1················· shr···· txdata1,#1····· wc
    txout1················· muxc··· outa,txmask1········· 'maybe patched to muxnc dira,txmask
    ······················· add···· txcnt1,bit_ticks1···· 'ready next cnt
    :wait1··············· '· jmpret· txcode1,rxcode2······ 'run a chunk of receive code, then return
    ······················· mov···· t1,txcnt1············ 'check if bit transmit period done
    ······· if_nc·········· jmp···· #:wait1
    ······················· djnz··· txbits1,#txbit1······ 'another bit to transmit?
    txjmp1················· jmp···· ctsi1················ 'byte done, transmit next byte
    ······················· jmp···· #transmit1
    'These are used by SPIN and assembler, using DAT rather than VAR
    'so all COGs share this instance of the object
    startfill
    · cog·················· long····· 0·················· 'cog flag/id
    · 'Dont Change the order of any of these initialized variables without modifying
    · 'the code to match - both spin and assembler
    · 'Dont make any of the initialized variables, uninitialized, only the initialized
    · 'variables are duplicated in hub memory
    · rx_head·············· long····· 0·················· '16 longs for circular buffer head/tails
    · rx_head1············· long····· 0··························
    · rx_head2············· long····· 0
    · rx_head3············· long····· 0
    · rx_tail·············· long····· 0
    · rx_tail1············· long····· 0
    · rx_tail2············· long····· 0
    · rx_tail3············· long····· 0
    · tx_head·············· long····· 0
    · tx_head1············· long····· 0
    · tx_head2············· long····· 0
    · tx_head3············· long····· 0
    · tx_tail·············· long····· 0
    · tx_tail1············· long····· 0
    · tx_tail2············· long····· 0
    · tx_tail3············· long····· 0
    · 'This set of variables were initialized to the correct values in Spin and loaded into this cog
    · 'when it started
    · rxmask··············· long····· 0·················· '33 longs for per port info
    · rxmask1·············· long····· 0
    · rxmask2·············· long····· 0
    · rxmask3·············· long····· 0
    · txmask··············· long····· 0
    · txmask1·············· long····· 0
    · txmask2·············· long····· 0
    · txmask3·············· long····· 0
    · ctsmask·············· long····· 0
    · ctsmask1············· long····· 0
    · ctsmask2············· long····· 0
    · ctsmask3············· long····· 0
    · rtsmask·············· long····· 0
    · rtsmask1············· long····· 0
    · rtsmask2············· long····· 0
    · rtsmask3············· long····· 0
    · rxtx_mode············ long····· 0
    · rxtx_mode1··········· long····· 0
    · rxtx_mode2··········· long····· 0
    · rxtx_mode3··········· long····· 0
    · bit4_ticks··········· long····· 0
    · bit4_ticks1·········· long····· 0
    · bit4_ticks2·········· long····· 0
    · bit4_ticks3·········· long····· 0
    · bit_ticks············ long····· 0
    · bit_ticks1··········· long····· 0
    · bit_ticks2··········· long····· 0
    · bit_ticks3··········· long····· 0
    · rtssize·············· long····· 0
    · rtssize1············· long····· 0
    · rtssize2············· long····· 0
    · rtssize3············· long····· 0
    · rxchar··············· byte····· 0
    · rxchar1·············· byte····· 0
    · rxchar2·············· byte····· 0
    · rxchar3·············· byte····· 0
    · 'when it started. They contain the hub memory address of the rx/txbuffers
    · rxbuff_ptr··········· long····· 0·················· '32 longs for per port buffer hub ptr
    · rxbuff_ptr1·········· long····· 0
    · rxbuff_ptr2·········· long····· 0
    · rxbuff_ptr3·········· long····· 0
    · txbuff_ptr··········· long····· 0
    · txbuff_ptr1·········· long····· 0
    · txbuff_ptr2·········· long····· 0
    · txbuff_ptr3·········· long····· 0
    · rxbuff_head_ptr······ long····· 0
    · rxbuff_head_ptr1····· long····· 0
    · rxbuff_head_ptr2····· long····· 0
    · rxbuff_head_ptr3····· long····· 0
    · txbuff_tail_ptr······ long····· 0
    · txbuff_tail_ptr1····· long····· 0
    · txbuff_tail_ptr2····· long····· 0
    · txbuff_tail_ptr3····· long····· 0
    · rx_head_ptr·········· long····· 0
    · rx_head_ptr1········· long····· 0
    · rx_head_ptr2········· long····· 0
    · rx_head_ptr3········· long····· 0
    · rx_tail_ptr·········· long····· 0
    · rx_tail_ptr1········· long····· 0
    · rx_tail_ptr2········· long····· 0
    · rx_tail_ptr3········· long····· 0
    · tx_head_ptr·········· long····· 0
    · tx_head_ptr1········· long····· 0
    · tx_head_ptr2········· long····· 0
    · tx_head_ptr3········· long····· 0
    · tx_tail_ptr·········· long····· 0
    · tx_tail_ptr1········· long····· 0
    · tx_tail_ptr2········· long····· 0
    · tx_tail_ptr3········· long····· 0
    endfill······ 'used to calculate size of variables for longfill with 0
    'note we are overlaying cog variables on top of these hub arrays, we need the space
    · rx_buffer·········································· 'overlay rx variables over rxbuffer
    · rxdata··············· long····· 0·················· 'transmit and receive buffers
    · rxbits··············· long····· 0
    · rxcnt················ long····· 0
    · rxdata1·············· long····· 0
    · rxbits1·············· long····· 0
    · rxcnt1··············· long····· 0
    · rxdata2·············· long····· 0
    · rxbits2·············· long····· 0
    · rxcnt2··············· long····· 0
    · rxdata3·············· long····· 0
    · rxbits3·············· long····· 0
    · rxcnt3··············· long····· 0
    · t1··················· long····· 0
    ······················· long····· 0
    · rx_buffer1··········· long····· 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    · rx_buffer2··········· long····· 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    · rx_buffer3··········· long····· 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    · tx_buffer·········································· 'overlay tx variables over txbuffer
    · txdata··············· long····· 0
    · txbits··············· long····· 0
    · txcnt················ long····· 0
    · txdata1·············· long····· 0
    · tx_buffer1········································· 'overlay tx variables over txbuffer
    · txbits1·············· long····· 0
    · txcnt1··············· long····· 0
    · txdata2·············· long····· 0
    · txbits2·············· long····· 0
    · tx_buffer2········································· 'overlay tx variables over txbuffer
    · txcnt2··············· long····· 0
    · txdata3·············· long····· 0
    · txbits3·············· long····· 0
    · txcnt3··············· long····· 0
    ····················································· 'overlay tx variables over txbuffer
    · tx_buffer3··········· long····· 0
    'values to patch the code
    · doifc2ifnc··········· long····· $003c0000·········· 'patch condition if_c to if_nc using xor
    · doif_z_or_c·········· long····· $00380000·········· 'patch condition if_z to if_z_or_c using or
    · doif_z_or_nc········· long····· $002c0000·········· 'patch condition if_z to if_z_or_nc using or
    · domuxnc·············· long····· $04000000·········· 'patch muxc to muxnc using or
    · txbitor·············· long····· $0401·············· 'bits to or for transmitting
    'If you want multiple copys of this driver in a project, then copy the file to multiple files and change
    'version in each to be unique
    · version·············· long····· 1
    ······· FIT
    Post Edited (pussycat) : 6/29/2010 5:46:06 AM GMT
    edited 2010-06-29 04:00
    pussycat: You need to post your code using the "Post Reply" and use the code icon. This preserves indentation. Otherwise, post your cade as a file.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    edited 2010-06-29 04:21
    pussycat said...
    2ms and 200ns seem worlds apart. Why are you so concerned about 200ns? At 80MHz that's only 16 cycles (4 instructions or one hub access window).
    edited 2010-06-29 05:49
    Cluso99 thanks for the suggeston.
    kuroneko I made a mistake about the time that is microsecond. I just find out that delay is not in assembly. it is pub decl () function call tx() for each number position(100microsecond delay between).·· I want to rewrite decl () function ( create ascii and then send str).
    (PUB decl(port,value,digits,flag) | i         'orginal decl code
      digits := 1 #> digits <# 10
      if value < 0
        -value
        tx(port,"-")
      i := 1_000_000_000
      if flag & 3
        if digits < 10                                      ' less than 10 digits?
          repeat (10 - digits)                              '   yes, adjust divisor
            i /= 10
      repeat digits
        if value => i
          tx(port,value / i + "0")
          value //= i
          result~~
        elseif (i == 1) OR result OR (flag & 2)
          tx(port,"0")       ' here is the delay
        elseif flag & 1
          tx(port," ")
        i /= 10)
    I send fix fixed-width 5 decimal place value. I changed code as following. but I have difficult to code· (create ascii and then send str) part.· where should I declare(in DAT or VAR ) that str?· and how to reference in SPIN··
    (PUB declc(port,value) | i ,flag ,digits
      digits:=5
      flag:=1
      i := 10_000
      repeat digits
        if value => i
          value //= i
          result~~
          tx(port,"0")
        elseif flag & 1
          tx(port," ")
        i /= 10)
    Post Edited (pussycat) : 6/29/2010 6:12:46 AM GMT
  • TimmooreTimmoore Posts: 1,031
    edited 2010-06-29 06:17
    In obex there is an object called obex_format.spin, it has a routine itoa that converted an integer to a string in a byte array. Take a look at that, it should be easy o use that routine for what you want.
    Hi Timmoore,
    thanks for your help. the format is real good example.
