Can not find AppBee
Since I just recently purchased a propeller demo board I bought the book "Programming and Customizing The Multicore Propeller Microcontroller". I decided I wanted to do chapter 5 with the XBee. So I ordered 2 XBee's. Then I went to order the AppBee's but the selmaware site said it has been discontinued. I did much googling but to no avail. Now what?
http://www.sparkfun.com/commerce/advanced_search_result.php?keywords=xbee&x=0&y=0&search_section=products
There are several other adapter boards available, as well. Just Google "XBee". You may need to extrapolate how you'll hook one up to your propeller board, but it's a fairly simple task (XBee talks TTL serial).
dgately
http://www.parallax.com/tabid/768/txtSearch/XBee/List/0/SortField/4/Default.aspx
Jim
Yep, I forgot that I used the adapters from Parallax as well... I had gotten some adapters from SparkFun when working on my Arduino projects
-dgately
Thanks for your replies though. It answers my question, just not in the way that I had hoped. I imagine after I have destroyed a few things I will probably figure it out. Or not.
An I'm not 100% sure, but I thought the SelmaWare boards had to be soldered also?
Jim
Glad you did not get discouraged. It should be easy to adjust the Parallax board to the Chapter 5 schematics.·I just need·verification from a Parallax employee that my diagram is correct. Sometimes TX/RX, DIN/DOUT gets turned around, depending on which way·you are looking at the connections.
Keep us posted!
Jim
